MilesR
- Mar 22, 2015
I hooked up the charge cable and it boots up partially then goes into charge mode. I think i have a dud. Bummed.
Dead as in drained, I can charge it. I tried to boot it up with another amp and it showed i had little or no juice.Well, it is about time for many DX200 with dead battery now , it is all within the limited longevity of Lithium. Luckily, it is cheap to replace, and Ibasso can be reached out to, very easily
Has anyone ever had an issue with the Amp modules? I have been only listening to AMP 5 for quite awhile. Recently I tried out AMP4s for a change, after listening I thought I would try AMP 1 reference. When I turned it on all I got was white noise. I changed out the amp to AMP 3 same issue, then changed to AMP2 still same issue, I then went back to AMP 5 and it works fine. Tried AMP 4s again this time just static. Using AMP5 no issues. Any suggestions??
That is weird and I have all the amps. I would try a factory reset on the DX or a FW reinstall and a reset.Has anyone ever had an issue with the Amp modules? I have been only listening to AMP 5 for quite awhile. Recently I tried out AMP4s for a change, after listening I thought I would try AMP 1 reference. When I turned it on all I got was white noise. I changed out the amp to AMP 3 same issue, then changed to AMP2 still same issue, I then went back to AMP 5 and it works fine. Tried AMP 4s again this time just static. Using AMP5 no issues. Any suggestions??
Yes, I did face this problem before. The odd thing happened to mine was it only happen on balanced... (including 4.4). I spent some time testing it at distributor shop, Zeppelin & Co. in Singapore but still could not figure out what was the cause. In the end, we had no choice but to send back to iBasso. With my warranty still within period, they replaced a new set for me if I remember correctly.Change the earphones you are using and/or cable to test if this is related to earphones. Crazy, but but I had some issues with the Noble Khan running balanced out of the Amp 8 and running Khan balanced using better quality cables. All I heard was noise.
go buy better Astell&Kern than ibasso! ibasso DX200 nothing support Tidal, and mango is blank player with bugged equalizer and not function filters! AK true support Tidal in stock menu and sound with tidal much better than poor blank player iBasso DX 200!! https://www.astellnkern.com/eng/content/main/I have no idea to be honest. I followed the instructions you gave me back then, I think it was about a year ago. It all works great apart from Offline Tidal , and that is the main reason I have a DAP.
