- Oct 14, 2013
Well, things change....and so does the mind. Let's see how big dx220 release is going to beBase on my experience with DX200 I will not get DX220 on day one...if i'm ever going to get one.
No information yet but it should be available soon.Battery hours?
Poscap capacitor is the same as in DX200TI
Yeah, and that also means DX200-EX would be another tier still ! Which makes DX200EX used at low price as a huge investment
@Whitigir, DX220EX?
Remember Titainum DX200 has
Hi guys I am looking for some feedback if possible. I have had my dx200 for over a year now and it has been flawless . If I am honest I don’t use it a lot and it’s almost exclusively used for TIDAL now. Offline tidal is a must as it will be primarily used when on my holidays. So I have a little issue. I am in Vietnam on my holidays and the albums I have downloaded from TIDAL stop playing. They play for a little while say an hour or so and then the listening becomes impossible. So I do a reboot and this helps , but only for a short while.
Does anyone else have this issue. It’s a huge blow as I am away and my music and the beach are what my break is all about. luckily I have some FLAC files too but the reason I have a DAP is for my holiday use
Do you have the DX200 in airplane mode and with WiFi off?Can anyone help me with this please ?
My only guess is your Tidal app may be trying to stream the offline files instead of play locally for some reason.
I use Tidal offline frequently and haven't had that issue so far.
I would suggest using it in Airplane mode and with WiFi off just to prevent it from trying to stream anything, as if it does and you have a bad connection it might not work. Mine is in airplane mode by default 100% of the time just to prevent any noise interference anyways.Thanks for the reply. Yes I have used it offline quite a lot too with no issues, but this was in the UK.
It would definitely not been in airplane mode and I think the WiFi would have been on,, but I can’t be sure .
It was also problematic whilst trying to go on tidal when I was in the hotel room,.it would just not connect to the WiFi . Whereas the tidal app worked flawlessly on the iPhone I had with me too.
I may sell the DX200 to be honest as it does not get used enough really and in that case is a bit of a luxury, and especially as it let me down on my holidays which is when I will use it most
I will experiment with it at home and see if it happens here now.
Just one thing are you suggesting I turn the WiFi off when I use offline music ?
I agreed and still love the SQ of DX204STI.
Let see how DX220 would really outperform the DX200TI?
