Lurker0
To check if the upgrade worked properly, just check the version as suggested here, presuming you didn't uncheck any firmware part in AndroidTool before flashing.Is there any noticeable change from v1.08, like the USB Audio version, which allow me to check if the upgrade worked properly?
For those who experienced device reboots and shut downs with the official build, the difference is obvious: with 1.09 the device is stable!
