Hi everybody, I want to return to official firmware from the Lurker's, and not sure how to do that. Lurker's site says To return to the official firmware, just flash it per its instruction. Is it the same instruction as for the Lurker's firmware, or you need to follow a dedicated instruction to flash official ROMs? Please let me know somebody. Thank you.
DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
- Thread starter Paul - iBasso
- Tags
- at8ie ibasso ibasso dx200
ranjitotski
- Dec 19, 2015
Where to buy that black leather case? Thanks! I don’t want my brown leather caseSame here.
Bluess
- Aug 4, 2013
Anyone got an idea for good modules in magisk for dx200? I see some interesting modules affecting system behavior and battery saving but afraid it may conflict with Lurker's mod
ranjitotski
- Dec 19, 2015
Just flash it with the original ibasso firmware nothing to worry! Same method in upgrading!Hi everybody, I want to return to official firmware from the Lurker's, and not sure how to do that. Lurker's site says To return to the official firmware, just flash it per its instruction. Is it the same instruction as for the Lurker's firmware, or you need to follow a dedicated instruction to flash official ROMs? Please let me know somebody. Thank you.
AugustineNg
- Mar 27, 2016
It is Lurker's addon, not mine.Thanks. I only have "0.01.08" in the build number. I'll try reflashing your add on again.
The first and second times I flashed, the tool indicated that it failed. It indicated a successful flash on the third attempt.
I only have the Magisk app, plus the other standard icons such as settings and clock.
But I suggest you to reflash everything including the original firmware then the addon.
In my experience, I have never seen any error in the AndroidTool. And you should not encrypt the DX200 before flashing.
Paul - iBasso
Sponsor: iBasso
Have you tried using the internal memory? For the SD card, we will fix this with a firmware update.In Mango OS, In Previous versions, when I long-press-click on the Folder that contains sub folders with music, it would bring the screen with "play", "+ Playlist" and "delete". When the play button is clicked now, it would play all the songs in random order (when random mode is enabled" across all the folders.
But in 8.1beta (with lurker add-on 1.09) nothing happens when the "play" button is clicked.
Edit: I should say that when the play button is clicked, it drops me back to the previous screen with the list of folders where I started from.
@Paul - iBasso, could we get this feature working. And DSD512 support back please?
Stay updated on iBasso at their sponsor profile on Head-Fi.
Lurker0
"Its" here means "official firmware's", the only noun in the first part of the sentence, obviouslyTo return to the official firmware, just flash it per its instruction. Is it the same instruction as for the Lurker's firmware
I've just upgraded to Oreo and keep getting the message " Google Play services requires an action". Any idea. How do you go back to 6.1?
Register your device with your google account(you can install Lurker-s update with instructions within).I've just upgraded to Oreo and keep getting the message " Google Play services requires an action". Any idea. How do you go back to 6.1?
Downgrade
1.https://www.facebook.com/flx/warn/?...Ud6eQTt4po6Ro62itTZrL0wS4TJWME9BnBd_QWM4AklVU
2. https://www.facebook.com/flx/warn/?...TffzRoIuzmHoJZS72NOaFDKwtbg3Q5dU1P1ZcFZnZX4YY
3. Install firmware with factory toot.
4. Install preferred(6-based) firmware
Thanks that second link is for firmware, I was wanting to go back to the original android 6.1.
hkppl
- Apr 3, 2012
Sorry if this has been asked for a while.
Is there any way to improve battery life of the DX200? My 1.5 year old DX200 with Amp8 now can run for around 3 hours max only, in pure Mango mode, that means it needs battery replacement already?
I tried to register it, but Google thinks it's a phone and part of the registration process is to ring it.
I just need an image of 6.1 so I can go back.
You want to downgrade to 6, right?Thanks that second link is for firmware, I was wanting to go back to the original android 6.1.
1. Download Factory tool
2. Download full firmware image. My link references to FULL firmware image.
After installing image(2) with tool(1) you can install what you want
It worked for me
Or in settings turn off the notifications for it . Thats what i did.I tried to register it, but Google thinks it's a phone and part of the registration process is to ring it.
It worked for me
Thanks, it worked.
Total: 25 (members: 0, guests: 25)
