AugustineNg
- Mar 27, 2016
The original battery of mine swelt like a balloon. I replaced it because of misleading battery reading which dropped drastically to zero after dropping to 50%.Sorry if this has been asked for a while.
Is there any way to improve battery life of the DX200? My 1.5 year old DX200 with Amp8 now can run for around 3 hours max only, in pure Mango mode, that means it needs battery replacement already?
If you don't know how to do it, find someone who knows to it for you, as the normal battery came with a logic board with 2 wires only, without the T wire.
AugustineNg
- Mar 27, 2016
Or in settings turn off the notifications for it . Thats what i did.
Read carefully of Lurker's addon readme.I've just upgraded to Oreo and keep getting the message " Google Play services requires an action". Any idea. How do you go back to 6.1?
After you could acquire the code in USB Audio, and registered it at the link provided, you have to wait until the status turns to 5 from 3 and reboot the device.
The notification won't come out again anymore.
ranjitotski
- Dec 19, 2015
Hayyys! Can’t wait for the official OREO FIRMWARE!
Bluess
- Aug 4, 2013
Where did you get the battery?The original battery of mine swelt like a balloon. I replaced it because of misleading battery reading which dropped drastically to zero after dropping to 50%.
linux4ever
What digital filter settings sound nice with AMP1, AMP1Ti, AMP2, AMP4, AMP4S, AMP7 & AMP8? DX200 & DX200Ti. Please share your impressions.
AugustineNg
- Mar 27, 2016
Electeonic DIY shopping mall in HKWhere did you get the battery?
A battery claims to be 4000mAh @ 3.7V with a thicker size and heavier than the original one which the case could barely be closed.
gannjunior
Guys,
got last 8.1+ 1.09 by Lurker. Solved google services advice google plays works fine so no more pop-ups...
Hoped the battery improved but, despite of the battery saving option flagged on, all apps closed, the battery drains more than 1% per hour (in stand by, android mode).
So I don't know if it is battery phisical problem or if it is, simply, a firmware problem since it's not just in its final realease...
Lurker0
Google Play Store sets too many alarms to send your data to Google. I disable Google Services (from USB Audio app) once I have installed all I need and launched them to let them check licenses.despite of the battery saving option flagged on, all apps closed, the battery drains more than 1% per hour
gannjunior
I'll try to follow your advice, mateGoogle Play Store sets too many alarms to send your data to Google. I disable Google Services (from USB Audio app) once I have installed all I need and launched them to let them check licenses.
thank you!
hkppl
- Apr 3, 2012
Can you PM me address of the shop in HK? Thanks.Electeonic DIY shopping mall in HK
AugustineNg
- Mar 27, 2016
Just find it at Sham Shui Po DIY shops.Can you PM me address of the shop in HK? Thanks.
There are lots of them
I sent mine back to ibasso after 15 months usage and it was returned to me with a new battery replacement costing 60+12 RMB. Given they are in shenzhen, i think its always a better option to back to ibasso
Glasha
Ok, I tried DSD512 and now I believe in God, the DSD God.
Can anyone post here some documentation that I need to play and make those files? I would like to use Foobar2000 to play them if possible. For now I'm playing them on my DX200
And I actually got some problems with my microSD
It's full
So now I have to decide if I want a 400 GB microSD or a way to use a hard drive maybe
It's full
Why not? It supports OTG if I recall. You can always connect a 2TB portable drive and mount it as a external storage I believe.
edwardsean
- Jul 7, 2006
I'm on Oreo 8.1 with @Lurker0 1.09 add-on. It keeps asking me if I want to upgrade to the full version of Magisk and then asks for permission to access media files. Is this a paid upgrade and something I should do or will it mess things up?
Total: 25 (members: 0, guests: 25)
