Have you heard the Progeny live album???
Close To Edge is probably one of the most badass live renditions I've ever heard. White's snare and Squire's bass are just sublime when paired with a competent iem! Curious if you've that album with these hybrids.
AZLA Sedna SS came. Larger than the "already a touch too big" tips I was using, some left overs from a cheap pair a long time ago, as they were smaller than the smallest tips that came with the unit. These SS honestly look as big as the regular smaller tips in the box.
If you need smaller than Azla Sedna earfits SS have you tried their short version. Then even smaller there are some branded as whirlwind and tornado but are the same thing. The small size is essentially the SS of sednas but shorter than their short.
Beats me, It is a really fine IEM with superb dynamics and a faultless SQ! It seems to have gotten bypassed by the hype of the latest flavors of the month.
It is interesting how a earphone with no real weaknesses and so many strengths gets little traction. Maybe It is because of Luna? Is there anything in the sub-$300 range that can seriously compete with the DK-2001? The Moondrop Blessing 2?
I had to make a blind choice between dk-2001, blessing 2 and isn h40. Went with Dunu based on a mix of graphs and reviews (particularly bass descriptions), design / schematics / beryllium (wanted guaranteed comfort, both the others are huge and I already had a big resin shell design in t800s), modular cable (at this price I expect to be given a choice of termination - isn also provide this, but the s8 cable isn’t nearly as good as the dk-2001s...) and looks (I waited for turquoise).
Of all my sets it would be the easiest to recommend because it gets everything right and has no weird Achilles heel (e.g. being hard to drive, tuning spikes, prone to condensation, driver flex, needing new cable and/or tips, too big). The icing on the cake is the infinitely superior unboxing xperience, the incredible fit and finish and the overall sense of design purpose that you feel when you handle it - you can just tell their manufacturing tolerances are way higher than anyone else’s. It’s a real surprise.
I would talk about it more but too busy enjoying music with it
For what I’m listening to it’s great (Biosphere, Koan, Stereomantra, Cabeiri, Astronaut Ape, Jaia...down/mid tempo, spacey stuff) but if sub bass extension is critical for you then there might be better choices. The 2001s bass is linear with relatively quick decay. It is overall very very holographic though, so really brings out good production. And they’ve got a really good balance between clarity/detail and smoothness.
I’m afraid not, though I was considering both it and the 4001. In the end I decided I just wanted to test the waters before going for any higher end stuff.
The DK-2001 is able to handle everything well. You can always use Dunu’s different ear tips to tweak the FR graph. Those bass tips really boost the bass if that is what you are looking for.
I was comparing them as similar-priced earphones for overall performance. I was not thinking theywould have similar sound signatures. I should have been more clear.
