I
posted this information in the Earbuds Round-Up thread and want to share it here as well. This is not to belittle or complain about the Alpha 3 earbuds. It's a follow-up on my thoughts about the Alpha 3 lacking in bass extension and my experiments to tune the buds for better bass and overall sound. Some people will be very happy with the tuning from the factory and that's ok, no problem if you're happy with how they sound. Myself and a couple others feel the bass is lacking, so this is my mod to tune the buds for better bass and overall balance. Maybe share this with the designers and see if my mod makes the buds sound better to them too(?).
Alright guys, I have the Alpha 3 bass mod for those that want to turn a good bud into an excellent bud.
Per DUNU's product feature description:
"Invisible Surround Multi-Channel Acoustic Vent Design Architecture: In order to get a truly high-resolution sound performance with the pair, DUNU has designed the Alpha 3 with a surround multi-channel acoustic vent design with vents placed on the back of the shell. The vents are invisible as they are hidden with the tip of the earbuds on the back side of the shell."
In DUNU's product shot below, you can clearly see some of the vents in the bud in the forefront.
By completely covering those vents with very thin tuning foam, the buds are tuned for very good bass extension and a more balanced sound.
Hey
@o0genesis0o, since you are doing some earbuds DIY, you might have some very thin tuning foams and give this a try and also give us some objective FR measurements. I think you will see and hear the bass is tuned much better.
EDIT: I tried using some 3M Micropore tape first and it did not give the results I was looking for. Here's a
link to the very thin tuning foam I used. It's much thinner than the standard low density foam of the regular low, medium and high density tuning foams people usually use for tuning buds.
