This driver is not perfect but there is something about it that often brings me back to using it. Pure silver cable and the hard metallic shell will increase the clarityHi Friends, glad to see everyone still active building stuff and helping each other to get into this dangerous hobby.
I bought this 300 Ohm driver, after thinking back and forth, finally decided to pull the trigger. I put it in the usual MX500 housing, removed the foam on the driver and put a new pair of foam on the housing. Used standard twisted pair cable, which according to the seller is a silver plated cable (SPC). Ran it through approx. 24 hours (not continuous) with pink noise, random music on my playlist.
My impression on this pair: It reminds me of a full range speaker. Very intact, very good texture from midbass to lower treble, but not much extension into the deep bass or the high treble. The overall sound is not offensive, I agree with @furyossa below. However, I feel they are lacking in resolution and clarity.
Do I:
1. Let it burn in some more, considering some say SPC needs 50-100 hours to sound best.
2. Do some kind of tuning, for example the cotton tuning on drivers holes, or any suggestion please feel free to share.
3. Change the cable to a good copper cable? I don't like the current SPC since it holds its shape too much, it gets tangly and overall not really nice.
Hehehe thanks a lot guys.
DIY Earbuds
- Thread starter gwompki
Last night I tried HE150Pro with Sam L compensation file. With his correction sound is more refined, mid-bass quantity is reduced a bit and mids are cleaner. The stock version already has fantastic sub-bass and soundstage.Its not lacking bass but I want more bads and more warmness in bass. The 130 ohm is more detailed than the 600 (maybe because of brightness?) to my ears but the soundstage is alot wider on the 600ohms.
the housing and foam pad I used is in the picture.
I think that he meant this modelAre these the 64 ohm drivers you are talking about ?
www.aliexpress.com/item/1005001357620077.html
Don't play with "8-packs".Seriously don’t touch anything, use only the first two, up at the topanother question on the 130ohm driver. Theres soldering iron on the “lf” and “hf” what are those? Can I try to solder the wire to it? Or should I remove those solder or just leave them be? Thanks
Can you please recommend "undisputable" set with ali links to purchase (incl MMCX connectors if any) to build for first time ? Forget to add - considering balanced connection to Hiby R6 Pro,
Can you elaborate a bit more? Undisputable? Are you looking to build your model or?Can you please recommend "undisputable" set with ali links to purchase (incl MMCX connectors if any) to build for first time ? Forget to add - considering balanced connection to Hiby R6 Pro,
I mean, here a lot of different links to the sets you are experimenting with, i'm asking something which, let's say, must have while you consider your own build for first time. Or either already passed common confession and it is good quality and sound on the end.
Thanks.
Themilkman46290
I had those same shells before, tried many drivers through it, you are right, in those shells the 130 ohm didn't sound very goodIts not lacking bass but I want more bads and more warmness in bass. The 130 ohm is more detailed than the 600 (maybe because of brightness?) to my ears but the soundstage is alot wider on the 600ohms.
If you still have the mx shells try the mx shells with a 0.8mm whole directly in the back and a full 7.1 foam
I agree.I had those same shells before, tried many drivers through it, you are right, in those shells the 130 ohm didn't sound very good
Here some examples for back vent #1 and #2Its not lacking bass but I want more bads and more warmness in bass. The 130 ohm is more detailed than the 600 (maybe because of brightness?) to my ears but the soundstage is alot wider on the 600ohms.
Here are 3 experiments with a 130ohm driver. In "PART 1" I used the same shell as yours but black. PART 2 build is most suitable for this driver
Try RY4S Plus and the 300ohm version. https://www.aliexpress.com/item/33038850404.htmlI mean, here a lot of different links to the sets you are experimenting with, i'm asking something which, let's say, must have while you consider your own build for first time. Or either already passed common confession and it is good quality and sound on the end.
Thanks.
If you want to make your own model then in the RY Earphone Store and NSC Audio Store you can find all parts for your build
Again! Super thanks!Try RY4S Plus and the 300ohm version. https://www.aliexpress.com/item/33038850404.html
I am new to this diy earbuds
I do need these kind of links
Many thanks, i was looking on it, now will order.
M/t can you please point out where to read how to solder balance cable instead of usual one ? Is there special unit must be or any are possible to convert to 4,4 pentakom cable ?
Ok, here we go. Lately, the question has often been asked is where to find earphone or headphone parts for DIY?
Of course, you are welcome to suggest more links and I will update the list. But for now, let's sum up
>>>>>>>>>>>>>>>>>>> DIY EARBUDS PARTS LIST <<<<<<<<<<<<<<<<<<<
***For DIY Earphones parts there are several stores on Aliexpress. with a very diverse offer.
Most of the stores have the same parts, so it's a good idea to check where the parts are cheaper.
- NSC Audio Store
- JieTu Audio Store
- XinYue Audio Store
- DIY Earphone Tribe Store
- Chitty's Store
- CKLewis Audio Store
- yuming Store
- RY Earphone Store
***For Plug and Connectors related to DIY cables (or audio equipment)
- QYFANG Official Store
- Zeatop Hendar Official Store
- R Connector Buy Official Store
***For pre-made "fancy" cables
- XINHS HIFI Audio Store
- KBEAR Official Store
- NiceHCK Audio Store
- Wooeasy_Earphones_Store (all in one place)
This can be an interesting and useful info
Modular "AIO" Cable parts
Making Balanced Headphone Cables By Rob Robinette
DIY and Mods
Balanced vs Unbalanced Audio Connections
Headphone Jack and Plugs: Everything You Need to Know
Pinouts for DIY
Soldering TIPS
- NSC Audio Store
- JieTu Audio Store
- Chitty's Store
- yuming Store
- RY Earphone Store
DIY and Mods
Pinouts for DIY
Soldering TIPS
rprodrigues
Of course, you are welcome to suggest more links and I will update the list. But for now, to sum up
- NSC Audio Store
- JieTu Audio Store
- Chitty's Store
- RY Earphone Store
***For pre-made "fancy" cables (NiceHCK, Yin.Yoo ,KBear)
I love you.
I love you.
you welcome
