I didn't post how I build that model. I use Electric Mini Drill for the inner hole and sandpaper to shape the outside. You can find it in a local hardware store probably.Thanks @furyossa For now I let it burn in some more, and it is improving. I'll keep your advise in case I got the itch to mod it in the future.
Could it be the correct "timbre" and the natural mids that make it easy to listen? As I said, in the MX500 housing it reminds me of a single driver, full-range speaker.
Tag: 300 Ohm N52
Did you ever post how you bore out the wooden piece? Was it by lathe? Sorry if you've posted here, I've searched but couldn't find a specific mention.
What will be the effect if the chamber is not conical shape, say, a straight cylinder? By saying "enlarging the inner space reduces mid high" does it mean this tuning benefits treble-heavy drivers, and bass-heavy drivers will have even less treble? I'm thinking of another project in the future, not using 130 Ohm Beryllium driver.
Thanks for sharing, my friend.
Tag: wood, wooden
The inner cavity will be cylindrical. On the drawing in the previous post, inner walls follow the shape of outside the wall. This is good only if you have hardwood otherwise the shell will crack. And by hardwood, I mean "stabilized wood".
