jmills8
Previously known as bmiamihk, jmills2
YesWould you say that $1100 is reasonable for a used TH900 mk2?
Copoer , Fiio makes an adaptor. Or have the 6.35 removed.Awesome. Thanks man. What would you recommend for a 6.35 mm to 3.5 mm adapter for its stock cable?
Nice mod.
I guess, it is due to the wider inner circle of the pad openings?
For me, that's the main reason i didn't bought the Denons in the past.
With the 009 pads, the auricles has a lot more air to breathe and the outer ears receives more of the sound waves.
I really wanted to like the 9200 however ultimately ended up returning the headphone to seller. Most of the user feedback and reviews of the 9200 suggested that it's a refinded version of the 7200, but after a closer encounter with the 9200 I realized that it had a completely different sound signature. The main reason I sent it back is its lack of lower end punch and its brightness: music just had not enough body for me sounding somehow lifeless and the hot treble attracted attention to itself too much. Back to my beloved 7200 and happy again. Enjoy the music!
Which one do you find yourself leaning more towards? The TH900 or 9200?
As to the cable topic, if anyone also has the D7200, could you try those cables with the D9200 and report back what do you hear?
I consistently enjoy more the D7200 cables with the D9200 (and vice versa).
Extrapolating from there, I assumed that pure copper cables sound better with the D9200 than silver plated copper.
I tested that hypothesis with 2 cables so far and it seemed true: improved micro-dynamics, better sound balance (a bit deeper sound) and less treble spike (actually, more defined treble).
Also, it seems the larger the copper strands diameter, the more the effect described above. If you don't mind stiffer cables, 0.3-0.4 mm strands work best IMHO: dynamic, transparent, clean, well defined.
I have also tried pure silver cable, which also sounds better (mainly smoother) than the silver plated copper - though I still prefer the "copper sound" with that headphone.
Conversely, the D7200 benefits from pure silver and even from silver plater copper (D9200 cable). Funny.
I was wondering if it was just the psychology of change? Perhaps, but not sure, as I had multiple testing rounds over the past months, consistently with the same results.
well i have chord tt2 and auris euterpe. definitely i prefer to listen to my denon on euterpe with chord tt2 as a dac to the euterpe, its not even comparable, for first time I know what a dam good tube amp means, unlike those lousy dark voice, or la figaro amps are. Get the euterpe and add a great dac to it and you will never listen to your headphones on a solid state amp again.Some headphones react better to tubes, others to solid-states. I find D9200 sounds best out of solid-states. Not difficult to drive either.
My preference is to make D9200 dry sounding to get more resolve because when a little wet, sounds becomes too less distinct and it's technicalities doesn't seem as impressive. This is why I prefer soli-state and not tubes. TH900 benefits from tubes in comparison.
The impedance is low, so make sure the tube amp has low impedance as well. I think BH sex would work as it has 4 ohm output impedance.
Tube amps in general are hit or miss, causes sounds to blend, although there are rare ones that separate sounds well. Like BH Mainline for example I dislike due to blended sound and lack of power for being their flagship model with the most expensive price.
Headphones that really benefits from tubes are Sennheisers.
so are now vocals less full, and more recessed as to me what i adore bout the denon is how it reproduces vocals. i tried so many pads and gave up, the fact is only stock pads sound best with 9200Important update.
I followed @zolkis tutorial,buy a pair 009 earpads and remove the White Rings.
Today the pads arrived,after finish work i tried my denon.
Is simply another headphone.
I start to say that the soundstage become really impressive,equal to hd820 (ex owner).
High frequencies become simply much Better,more definied but the excessive sharpness is totally gone.
The middle frequencies are slightly recessed, but are even more natural than before and the listening experience result less fatiguing,but the punch Is always here.
Bass frequencies are spectacular,more choerent in sound timbre in general.
The reverberation of instruments and voices has improved dramatically,these headphone simply sound totaly Amazing.
sounde more organic and natural,microdetail improved....really i'm speechless.
I know,for 180.00 € a earpads pair aren't cheap,but of you want a closed headphone better than utopia (logically IMHO) with 820 soundstage you MUST buy these pads.
Amazing.
amazing
I take this opportunity to thank so much @zolkis and for his patience.
fantastic mod.
Incidentally the modded 009 pads help with the treble issue, it makes deep bass more impactful and larger sound stage.
Myself I use the modded (damping, damper rings, pads) TH900 for movies + games and the modded (pads) D9200 for music (including music movies), when I don't reach out for my e-stats. Both are keepers.
The mD9200 has more sub-bass impact with a more dry but accurate bass, the TH900 has more bass impact with a bass bloom and some coloration in the mids and treble.
The D9200 has slightly clearer sound with more perceived resolution (meaning not treble, but fine nuances in sound), but transparency, resolution is similar.
The TH900 is slightly louder (very efficient drivers/enclosure), but I guess that is also the reason for the more colorations.
Logically my toughts are based for my ears,you said vocals less full,while in my hopinion i feel "more analogue sound"...so are now vocals less full, and more recessed as to me what i adore bout the denon is how it reproduces vocals. i tried so many pads and gave up, the fact is only stock pads sound best with 9200
i adore the denon 9200 and the only downside for me is i can not find stock pads to buy to keep the same sound signature, as I find myself keeping the denon for a very long time, and i always like to have my gear in mint condition, and maybe the stock the pads will wear off with time, so I like to have spare stock padsLogically my toughts are based for my ears,you said vocals less full,while in my hopinion i feel "more analogue sound"...
