schneller
- Jan 14, 2007
Wish I could get a Naim DAC V1 into Gary's hands. The real magic only begins north of $2K
^ You got it Mike!
And LugBug's is the thread
I still can't get my head around how good it seems to be. A piano track I used to play (some Debussy I think) was made soupy by the Bifrost, clear and highly resolved by the Bushmaster and close to how I hear it at a piano. Chords were resolved into their component notes yet there was rich timbral/harmonic information too. It sounded completely authentic from this cheap dac - what?!... :eek:
...Bottom line is I think I will chill and go hear what I can actually hear LOCALLY and just TRUST my ears! I think I will take a pass on trying to audition every possible DAC in my price range!
After reading this thread, I decided to purchase a emotiva stealth dc-1 to compare with the gungnir and concero for myself, with the hd800 and vali. Will also get an oppurtunity to compare with the M7 using a DNA stratus as well next week.
I'd like to emphasize Armaegis' post from a couple of days ago. I think you nailed it.
Good advice. I'm still sort of shocked because it's a weird feeling looking at all those different DACs and expecting to hear differences and not hearing them.
Comparing the LCD-X and the LCD-3--they sound miles apart to me, and switching out our amps, they have very different signatures. Most of these DACs are so close in sound--it's like a hair's width of difference at the limit of your hearing.
I really wish Gary had a couple of A-GD DACs to compare. I'd love to be talked out of getting an M7.
I'm looking forward to your findings, as I've recently ordered a Schiit Vali to audition with my HD800 and I've read (but can't say if it's really true or not) that the Vali > HD800 pairing is very DAC-sensitive. So, your forthcoming tests are of great interest to me.
For the record, I'm disappointed in my new HD800 - at least with the gear I've got currently. I'm willing to try a few different DAC and amp combos (while trying to avoid tube rolling) to see if I can accommodate the HD800, but if I can't "fix" it, I will be tossing it into the For Sale bin, as I did my "incurable" Beyerdynamic T1.
Mike
(Addicted, perhaps, to the sound of an LCD-2 rev. 1 on neutral signals...)
Mike
The HD800 is a picky bugger, but ultimately the amp will make a bigger difference than the dac. Also look up the "anax mod" for the HD800 which helps tame down a bit of the treble edge. If you're still learning towards the LCD2 sound though, the HD800 may simply not be for you. I'd recommend the HD650.
Oh, and I can add that as of tonight, you can add the Ciunas to the Metrum as being different from the "indistinguishables". I need to do some detailed testing, but the differences, while subtle, are reasonably clear to me, at least tonight. What I can't say is whether the Ciunas and Metrum sound alike, since I haven't level-matched them. Consider that a coming attraction.
Indeed, the Anax 2.0 makes a significant difference in the mid to treble transition. Much smoother than the stock sound. It really fixes most of the treble problem for most people but may still be too bright with a SS amp.
I wouldn't pin the "brightness" on SS architecture alone. A tube amp can sound bright just as much as a SS amp. Now, if an amp has a higher output impedance this can result in a midbass bloom which would make a headphone seem less bright, but again that can happen with SS as well as tubes.
