I heard the paw for 30 minutes at RMAF and the mojo for 2 hours at a friends house so take it for what it is worth, but I would not hesitate to get a mojo, it is equivalent to the paw with a different sig. The paw is more dynamic and textured with the mojo being more elegant and airy. I want both and feel they are at the same level of SQ far above the other portable options. Adding an amp to the x7 or my ak100ii can get them close. The value of the paw is as a single stack, but I am now on the paw tour to dig deeper to see if I can overcome the paw look and ui. Both the paw and mojo are incredibly small which you will not understand until you hold them in your own hands. - Bill
DAP-off! Astell&Kern, Sony, HiFiMan, Chord, FiiO, Lotoo, Soundaware, Hiby, Cayin & others
- Thread starter Currawong
- Tags
- astell-kern-ak240 aurender-flow calyx-audio calyx-audio-m chord chord-hugo chord-mojo cozoy cozoy-aegis-portable-24-192-dac-amp cypher-labs-algorhythm-solo-db fiio fiio-am5-high-power-amplifier-module-for-x7 fiio-x5-2nd-gen-premium-hi-res-dap fiio-x5-high-res-portable-music-player fiio-x7 hifiman-hm-901 lotoo-paw-gold luxury-precision sony-walkman-nwz-zx1-128gb-mp3-player-hi-res soundaware soundaware-m1-esther
Wyd4
I would agree. I ended up buying the mojo as the paw gold was out of my budget.
They are both very small, but quite thick.
Mimouille
I would also put Lotoo Paw Gold and Mojo at the top. And Aune M2S not far behind.
CoLdAsSauLt
Thanks a great bunch guys.
Am I the only one who doesn't have a massive music library because he only recently stepped into this hobby, so streaming was a more interesting source, diversity wise? Or am I seeing this wrong, and are the other transports capable of e.g. Tidal offline mode as well?
On top of that, I see people making a size argument, yet they use a separate transport with Mojo. Do they just need all those GB? Or am I missing a point here? Because for compactness, why don't I see loads of people using their phone as a transport? I never leave my home without it. Carrying that plus a Mojo is already quite a mini-stack. Adding a transport brings that number up to three devices to drag around...
masterpfa
- Dec 30, 2014
It's all down to personal tastes. For most uses your phone and Mojo will do fine but for those who do have a large library or do not want to tie their main means of communication to the Mojo, they would get an additional DAP, I recently got an AK100 tiny and compact and no fear of running my phones battery down if away from home for a while.
FidelityCastro
- Dec 22, 2014
+1
Phone is a great transport (I used 128GB iP6 for ages with a Hugo or an ALO CDM and it sounded great).
BUT: it's a pain having your phone connected to another box all the time - in a world of SMS, email, Google searches etc etc, and having to connect or disconnect it - basically to use it as a modern mobile phone - is not convenient. The battery also gets run down fast. And having a separate DAP means you can take it out solo on those times when carrying an extra box - even a small one like a Mojo - is not ideal. Yes you can do that with a phone (I did), but a nice DAP with a balanced output really does sound better.
For me it is all about the use case. Working from a home office seldom on the road, the phone is not an issue and for use at night to listen in bed, no issue. However, if I was a heavy phone user, it would not be ideal, nor would I be listening to music to begin with given the inconvenience.
Another thing, I may have a massive library, but using iTunes, I have made it a habit to turn listening sessions with my main library into playlists that I can sync with my phone. Of my 18K songs, there are only about 2K that I actually like enough to look for and select, and only half of those are in a high res format that I care to listen to. 2K songs can easily fit on a MicroSD card and by limiting to my favorite playlists, a subset of favorites easily fits on my phone. But there are those that insist on having all their music with them at all times for some reason - to each their own.
In terms of transport. Trying the different inputs, I found my iPhone to sound better than my DAPs - AK100ii via optical - as a transport probably due to the excellent USB implementation vs. my crummy portable cables. So the iPhone might even sound better.
cattlethief
- Nov 30, 2012
The Aune m2 basic isnt far behind the mojo punching well above its weight and cost,it betters my AK100ii and Pioneer solely on sq.
San Man
- Dec 21, 2015
I agree. I started with my iphone and the mojo, but the cable solution leaves MUCH to be desired as far as ergonomics and portability (as far as finding a way to not kink the cables). Decided that it wasn't the way for me to go and bought a 100 too.
Got a smoking deal on the 100mkii, and it comes in tomorrow
Mimouille
I agree. I haven't compared side by side, but the Aune is competing with the Mojo.
CoLdAsSauLt
Thanks for all the reactions. What about the amp section of the Mojo? Is everybody evaluating the DAC section with some easy to drive (C)IEMs, or are above claims also valid for some harder to drive full cans (so Mojo vs the balanced outputs of some of the afore-mentioned DAPs).
Thanks a great bunch!
I've A/B'ed the QP1R, AK380AMP and Lotoo Paw Gold recently and here's what I've found:
Bass: Lotoo Paw Gold > AK380AMP > QP1R;
Mids: AK380AMP > Lotoo Paw Gold = QP1R;
Highs: Lotoo Paw Gold > QP1R > AK380AMP;
Soundstage: Lotoo Paw Gold = AK380AMP > QP1R.
FYI headphones used were UM Mentor and AKT1P
I also had the chance to compare HM901 minibox and Calyx M side-by-side with LPG.
Long story short: the two have zero advantage over the Lotoo, while the Lotoo has better bass than Calyx M and better highs than the HM901.
Still haven't had the chance to audition HM901S and the Tera. Will report back when I do.
badwisdom
- Sep 13, 2009
Not bad for more than half the price......
If you weren't already aware, I posted my Chord Mojo review. I recently added the video to it:
http://www.head-fi.org/products/chord-mojo/reviews/14747
The video is 30 minutes long, and includes a lot of comparisons, my thoughts on it with full-sized headphones and IEMs.
Mimouille
Can you do a TLDW summary in 4 bullet points
