- Jan 29, 2010
I prefer the Theorem over the Hifi m8, more refined and smaller
Guys, I just got a Samsung S4 with the latest update. what do I have to do to make it work with my Theorem?
I don't know too much about phones as DAPs. Thank you for the help
Q: How do I connect to Android devices?
A: Tracks of resolutions up to 24/192 now play from Android devices through the Theorem 720 DAC or AlgoRhythm Solo –dB, at full resolution in asynchronous mode. Simply load tracks, or entire folders of tracks, onto a micro SD card, connect the devices and play tracks using a USB audio application USB Audio Recorder Pro.
Equipment needed:
• Theorem 720 DAC or AlgoRhythm Solo –dB
• Android device, such as Samsung S3 or S4
• OTG male micro USB to female USB A
• USB A to USB mini B cable (supplied with Solo –dB)
• USB Audio Recorder Pro application for Android, created by eXtream Software Development, $6.00 on the Google app store
• Headphone amplifier and headphones
• Recording format selection: wav/flac/ogg/aiff (No mp3)
Procedure:
1. Place high resolution music files on a micro SD card. Placing the files in folders allows the use of playlists
2. Load the micro SD card into the Android device, such as the Samsung S3 or S4 phone
3. Purchase and install “USB Audio Recorder Pro” (be aware of similarly named apps) (https://play.google.com/store/apps/details?id=com.extreamsd.usbaudiorecorderpro&hl=en)
4. Connect a micro USB OTG cable to the Android device
5. Connect the Solo -dB to the OTG cable using the standard USB A to USB mini B cable
6. Turn on the Android device
7. Turn on the Solo -dB
8. Start the app “USB Audio Recorder Pro”; starting the app first will not work; if the app is running before turning on the Solo -dB, then kill the app using Application Manager
9. If the two devices are connected properly you will see the Cypher Labs USB 2.0 device listed in the Input section of the app
10. On the Main tab of the app, navigate to the external SD card and select a track to play and press the play button on the app
11. Use the playlist feature to automatically advance tracks or shuffle tracks
12. For more information on the app itself, eXtream Software Development http://www.audio-evolution.com/
Other Requirements and Notes:
• Android 3.1 or higher
• Android device with USB host capability
• The Theorem 720 DAC or AlgoRhythm Solo –dB will not charge the Android device
You can check below for the instruction:
Can someone recommend good IEMs for the Theorem around $200-$300. I am very much enjoying the theorems with full headphones but would want to try IEMS.
TIA
The Theorem tends to have quite a bit of background noise with IEM's. I've yet to find an IEM where there's no background noise when used with Theorem 720. I can't be bothered as I prefer full size cans but I did try some Shure SE535's, Atrio M7's, Hippo VB's, some Westone's (forget the name) and they all hiss more or less (obviously on lowest gain setting).
Did you try it with the Earsonics SM64?
thank you very much for that. So you always need to buy the software to make it work. Appreciate the effort.
TIA
My local headphone shop has some. I'll see if he has a pair on display that I can try out. Going there tomorrow so I will let you know.
It is better please buy from The same company : USB Audio Player Pro
UAPP is The best USB audio Player yet , has The best SQ and has better UI than USB Audio Recorder Pro
IMO
