tgx78
Member of the Trade: tgxear
![3641308A-8D3D-4046-AC0B-B632E3BDDF12.jpeg 3641308A-8D3D-4046-AC0B-B632E3BDDF12.jpeg](https://cdn.head-fi.org/a/11331937.jpeg)
![E18DF0B7-66E6-474D-9F7F-BC182C49B28D.jpeg E18DF0B7-66E6-474D-9F7F-BC182C49B28D.jpeg](https://cdn.head-fi.org/a/11331938.jpeg)
You can not gauge technicalities from frequency response graph. Maybe waterfall plot but not from those above.
There are a lot of people who don’t like the EJ07, hence the “short bus”. All that matters is what you think of it. He has the IER-Z1R rated as an “S”, but there are plenty of people that don’t particularly like it.But why the EJ07 is so bad? Its technically and soundwise on par with Monarch and Clairvoyance.
Thanks for saying that. It's a club for 'special' folks.There are a lot of people who don’t like the EJ07, hence the “short bus”. All that matters is what you think of it. He has the IER-Z1R rated as an “S”, but there are plenty of people that don’t particularly like it.
Omg, very tough! This is my best go at this:What is your top 3 favorites QDC?
Nice. What is special about the black vx.Omg, very tough! This is my best go at this:
1. VX - I have the special black ones only sold by certain vendors
2. Dmagic 3D
3. Gemini
4. 4SS
4. 5SH
I have 6 of their IEMs and 4 of their wires
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
I always wanted to go demo the qdc but the showroom is quite far away.
also the shop told me all models of qdc need to be preorder now , no stock in thailand
Thanks.Doesnt have qdc connectors. instead 2 pin.
Thanks.
Is the qdc unique only to qdc? That means typical 2 pin and mmcx cannot be used right
only have to buy made for qdc connector cable?
AFAIK, “qdc” is a commonly used name for that type of connector, probably made famous by qdc, but it is certainly not unique to qdc now. It is a rounded, protruding 2 pin socket. I believe that actual qdc sockets have reversed polarity vs traditional 2 pin sockets, but as long as the right and left cables are attached the same way, it doesn’t matter. Regular 2 pin plugs will work with qdc sockets, but the plugs will stick out a lot from the IEM shell. There are also some qdc sockets that take the 0.75mm two pin plugs rather than the 0.78mm plugs, but I think the consensus is that it doesn’t really matter b/c that is such a minute difference, and manufacturing tolerances may even be more than that difference.Thanks.
That 0.03mm actually makes a huge difference, if you use a 0.75mm on your 0.78mm sockets, be prepared for your IEMs to go flying across the room if you’re not extremely careful. And using a 0.78mm connector in a 0.75mm socket will result in either not being able to fit the pins in or, worse, stretching the socket.There are also some qdc sockets that take the 0.75mm two pin plugs rather than the 0.78mm plugs, but I think the consensus is that it doesn’t really matter b/c that is such a minute difference, and manufacturing tolerances may even be more than that difference
S = U12t silky and fast highsBtw between Z1R, andro , andro 2020 , U12T how you would you rank it by best treble?
