Bullpride
Chris,I am quite well equipped in the headphone amp department, but, I also want to learn to build 'em. So, I'll build a Crack+Speedball to start that journey.
In terms of parts/ performance upgrades, I think we have:
Question:
- Potentiometer - a good stepped attenuator can cost as much as the Crack, but an Alps pot seems a good balanced upgrade?
- Resistors - Looking for thoughts here. Looks like sometimes a choke is used in place of one resistor post power-supply to reduce power noise too. Hammond? Wire-wound replacements - Mills?
- Caps - You can spend quite a bit here. Some can also be huge. Looking for thoughts here.
- Anything else?
I assume it is best to build it to manual spec first (no changed parts), then make changes? Is that the case? Anything worth just doing during the initial build?
I recently finished my build, and am asking some of the same questions you are.
1. Definitely build the stock crack first. Listen to it for a while. Then do the speedball. You can even do the speedball in stages. This has helped me start to recognize the differences in sound for each upgrade.
2. Potentiometer and Attenuators. There seem to be two suggested quite a bit:
One made by PEC
https://www.digikey.com/product-detail/en/KKA1041S28/KKA1041S28-ND/770961
The Alps Blue Velvet you mentioned:
https://www.parts-express.com/alps-...xte0RvVVRp4zTxgRciDFUTM59-A_3scRoCnikQAvD_BwE
3. Chokes - I think these fall under the "not necessary" category by the Bottlehead folks, but others suggest them
4. Caps - worthwhile upgrades, though I haven't done a lot of digging. The article below does a great job of outlining each of the suggested upgrades, with a decent break down of the individual Cap suggestions.
https://www.headphonesty.com/2019/04/upgrading-bottlehead-crack-headphone-amplifier/
5. I also found this article. The author commented on my post in "I love my Bottlehead" Group on Facebook. Moving one of the signal wires away from another group of wires cleaned up some noise I was hearing
https://www.hificollective.co.uk/bl...TyqZd_IqqNRs5S5pYOo5qtTTMObzAzVQaCDCnR1yX22Ec
This response is for you, but also so I have a handful of notes for myself, ha. The Bottlehead forum and this thread are an excellent source if you have additional questions. The folks on the forum are more than happy to help you troubleshoot.
