May 22, 2020 at 1:53 AM Post #10,006 of 12,435
I found one on ebay in black (probably not as good looking as those audio note ones!) that was only about 8 bucks. Shipping worries me, estimate is currently...July. I'll just have a non-fitting knob till then :).
May 22, 2020 at 6:21 PM Post #10,007 of 12,435
My build might give a few of you ideas on cabinet choices. This is walnut with maple splines and solid brushed copper. amp completed.jpgcopper front plate.jpg
May 22, 2020 at 10:17 PM Post #10,009 of 12,435
The VU meters look great! Do they add any noise to the circuit? How do you hook them up?
No noise that I can measure or hear. They go on the output stage, use a 12 v supply that I ran separately. Dual volume pots that are simple enough to install. I did another version that is outboard, uses a pre-amp out, tulip poplar with ebony inlays and splines.7B8F81E6-4088-4CC6-A3B1-51B7CBEA8D47.jpeg
May 22, 2020 at 10:36 PM Post #10,010 of 12,435
Those amps are for friends. My next venture will be a honey locust cabinet with copper and maybe holly splines.573B3F0A-2E0F-458C-8F08-D2C1DDC563E9.jpeg
May 22, 2020 at 11:25 PM Post #10,012 of 12,435
Clearly I need better friends :).
May 23, 2020 at 6:38 AM Post #10,013 of 12,435
Source for the meters?
Amazon or Ebay, they are not expensive but they can take a while to receive. I just noticed this seller and the price is very good.
https://usa.banggood.com/2-Pcs-VU-M...LMmHZ2G1UsvcJphoCZ1AQAvD_BwE&cur_warehouse=CN
It took me a while to find a hole cutter the perfect size but I have used these meters a lot and will continue to do so. I compare different headphone amps a lot and the meters are quick reference for me on signal level. IMG_1539.jpg
May 23, 2020 at 10:27 AM Post #10,015 of 12,435
A classy amp ...
Brushed copper can be time consuming but I love the effect. This is the start of a top plate for my own amp.
May 25, 2020 at 6:17 PM Post #10,016 of 12,435
Hey Friends!! Check it out...a quick video I did with a fun montage unboxing of the Bottlehead Crack OTL 1.1 Headphone Amplifier! I hope you dig it, I will post up more audio gear videos to the channel soon. Please consider subscribing to the channel and drop me a like on the YouTube video if you don't mind and let me know if you want to see part 2 and 3 of this video series in the comments! Have a safe and great start to your week.
MR
The Source AV TSAVJason Stay updated on The Source AV at their sponsor profile on Head-Fi.
https://www.facebook.com./pages/The-Source-AV-Design-Group/153623164648713 http://www.twitter.com/TheSourceAV http://www.instagram.com/Thesourceavdesign http://thesourceav.com/ Products@TheSourceAV.com
May 26, 2020 at 7:09 AM Post #10,018 of 12,435
MR
Hey man! Nice to see you over hear!
May 26, 2020 at 8:20 AM Post #10,019 of 12,435
I am quite well equipped in the headphone amp department, but, I also want to learn to build 'em. So, I'll build a Crack+Speedball to start that journey.
In terms of parts/ performance upgrades, I think we have:
  • Potentiometer - a good stepped attenuator can cost as much as the Crack, but an Alps pot seems a good balanced upgrade?
  • Resistors - Looking for thoughts here. Looks like sometimes a choke is used in place of one resistor post power-supply to reduce power noise too. Hammond? Wire-wound replacements - Mills?
  • Caps - You can spend quite a bit here. Some can also be huge. Looking for thoughts here.
  • Anything else?
Question:
I assume it is best to build it to manual spec first (no changed parts), then make changes? Is that the case? Anything worth just doing during the initial build?
