- Jan 10, 2016
@shigzeo I can't find your ocharakus review. Wanna read them again! Thks.
@shigzeo
(on a side-note: mhhm, a BlackBerry isn't the best device to type longer texts - just noticed all the spelling mistakes I made...)
The best thing is that Cowon has overcome the bass roll-off with low impedance headphones older models had. If they ever add a more usable scaling for quiet listening, I'll quite likely buy it again. Though, I highly doubt that to be honest (unless a RockBox port will be possible one day - the cheap Sansa Clip Zip also put out an abundant amount of voltage (read: too much for me) at the lowest volume setting, but RockBox was the cure for listening at lower levels and added a more usable scaling as well).
(measured with the Triple.Fi 10 as load)
give it a little time for the battery. But that seems very strange thoughI was about to ask the same. I still need to do a full test but I don't think mine last longer than 20-30 hrs either, listening to 320kbps MP3s stored on an external microSD card. :S
(I use an IEM and volume rarely goes above 20.)
is it good to pair ath-im02 with the Plenue D?
It should drive it perfectly well, so yes.
Not at all.Sorry I didn't write clearly, since im02 is bright and treble-centric, could pairing with plenue D make the sound too bright?
