- Jan 10, 2016
How to format internal memory pls help
Hello everyone, Does anyone know if there is software that gives download lyrics to many songs together and how you can see lyrics in Plenue d. Thanks.
I may be able to assist.
Cowon reads .lrc files. I use foobar along with adding the component foo_uie_lyrics3.dll (google it, or google Lyric Show 3). You can highlight a single file, album or entire collection and set it off to retrieve the lyric .lrc file for that song (if it has success in finding it). Furthermore you can stipulate that the .lrc file be saved in the same folder as the track also with the same identical file name. This is often required for things like DAPs to display lyrics. I can confirm it works on my AP100, I would hazard a guess it should work for Cowon DAPs too.
Lamb Of God will.Who else here likes their music loud? I mean really loud?
When other users say "I need it on around 65%" that doesn't make much sense to me so I need somebody's opinion who is a bit like me.
With my external DAC plugged into my PC or Samsung Note 3 I can get the volume so my Fidue A83s say 'no more' so is this player capable of getting to high volumes.
Would Slayer be in the room with me if I turned the volume up?
I have an issue with double albums being messed up because it doesn't seem to respect the disc tag. Is the only way to fix this to go through my entire collection and re tag them with different track tags? Seems a bit poor if it is but searching headfi it seems to be a cowon issue that dates back years
Am I the only one with this issue? When I sync double albums which play in the correct order on other mp3 players and my windows desktop to the Plenue D the tracks are played in this order:
1-01 (Disc 1 - Track 1)
2-01 (Disc 2 - Track 1)
1-02 (Disc 1 - Track 2)
2-02 (Disc 2 - Track 2)
i.e. it's ignoring the disc tag. Any easy fix I'm missing?
So far no.. Gladly!! Are use using the internal memory or the External Card.
