Dark Helmet
- Feb 9, 2013
Also what amps are you guys using?
Aune B1, Cypherlabs AlgoRhythm Duet are amazing with it. It's not bad by itself either but the amp extends the battery life for longer playing time.
If I use it without an amp I have to use the EQ, which is cool.
Is it possible to enter this VU Meter in Cowon Plenue D has equal in Cowon Plenue 1 or Cowon Plenue S? I was thinking about the possibility because I think it's cool, but I do not know if the screen size allows...
I'm thinking of sending this idea for Cowon.
Try it with the EQ off and turn up the volume. It will sound more true. At least it does for me.
anyone know best/most reasonable place to get one? in USA
