jmills8
Previously known as bmiamihk, jmills2
I still love the original X3. Great line out .and copared to x3 II?
For some reason I just can't place the PD in my cart. The battery life is great, but I still doubt the sound quality. As I understand it, the PD does not use a physical DAC, but simply a codec?
There isn't a DAP out there that has most of what I want. Great sound (yes, subjective to a point). Replaceable battery(paying >$600 is not disposable. I'd use the DAP for at least 5 years.) AMOLED screen. Compact. WiFi. Reasonable price. The top DAPs are way too expensive for what they are and they're still not complete. You can get a decent home heater receiver for the cost of some of the DAP"s out there.
How does the P1 compare to the PD? Slightly better sound for $600 more?
Enough ranting. More coffee.
can anyone tell me if Cowon Plenue D supports dsf file ?
Where did you get that info that is does not have a DAC?
"The PLENUE D is equipped with a high-quality, 24bit/192 kHz stereo DAC found in Hi-Fi audio systems to deliver outstanding sound performance including 123dB of SNR, 0.004% THD+N, and -105dB of stereo crosstalk. Featuring powerful performance in a small form factor, the PLENUE D is a portable Hi-Fi audio device that provides excellent lossless, high-resolution sound quality."
Update: The fan community meanwhile knows: There is no classic DAC built in the D, COWON uses a so called "codec": the Wolfson WM8998. I don't want to dive into technology just telling you it is a very good chip from one of the three/four leading audio chip making companies.
Also it appears that the PD employs the Wolfson WM8998 Audio Hub (codec) vs. dedicated hi-fi DAC (as in P1, PM, PS).
The above quotes from reviews on Amazon.
http://www.amazon.com/Cowon-Plenue-Resolution-Music-Player/dp/B01A8NU5CG
I've heard the X3ii for 50+ hours now. IMO the Plenue D is better audio wise but the X3ii has a dedicated lineout and supports DSD.
It depends what you're looking for. If you want versatility go for the Fiio X3ii, If you want portability go for the Plenue D.
As ever 'better sound' is subjective but 3 people I know IRL (and me) think the D sounds better, no-one chose the X3ii.
How can D sound better when D has no DAC chip but X3 has one?
I have X3 1st gen here... and it sounds alright... I think it's a little behind iBasso R10 in terms of gain power. Its UI is better than that of iBasso R10.
Isn't it nuts that no one can figure out what DAC is in the Plenue D? Anyway, I ordered it since I love the form factor and the touch screen. Time to sell the X1.
