mp3
- Sep 20, 2008
How does the Plenue D compare to Pioneer XDP-100R and Onkyo DP-X1? I guess I know the answer, but still.
Anyone know what is the settings for BBE headphone 2? I want to tweak it a little for my preference
This is my little hate, there's a few presets that are OK but might be better tweaked but no way of knowing the settings.
You'd think Cowon would have a leaflet showing the presets + settings.
Agreed. I like how some DAP's let you adjust the preset even and you can see it at least but not save over it. Even that would be nice to have.
I brought this up many moons ago here and on other forums, it was then and is likely to be now still a dead end. I was exactly feeling the same with my C2 and i9+.
What I will say is that I have discovered better settings on my own and with other members help on forums, it just takes time. You have to have the patience to really sit down and tinker, the diversity for sound signatures is very large with this device, and I believe it's all a bit of a learning experience, 6 months from now u will tweak to something new and get a lot from it, then another 6 months do the same again etc, sometimes it takes a year or so of owning to truly find your sweet spot, that's been my experience.
Anyway feel free to try these settings I have used, it gets mixed feedback with some literally saying "WOW! How has it taken so long to find this?! Sounds amazing!" to "Urgh... artificial and ghastly"
EQ
7 80 wide
-1 220 normal
5 1.4 narrow
6 3.0 normal
7 11.7 wide
BBE/JET EFFECT
bbe 10
mach3 8
3d 2
mp enhance on
steroe enhance 3
reverb off
or (for less bass)
EQ
7 80 wide
-1 220 normal
5 1.4 narrow
5 3.0 normal
6 11.7 wide
BBE/JET EFFECT
bbe 10
mach3 off
3d surround 3
mp enhance on
stereo enhance 3
reverb off
At the very least it may be a launching point for some of you. Eventually I never used the presets anymore and preferred tinkering, but it is also very genre dependent, I can imagine those settings working well in some genres but not others.
So I also would like to know someone's impression/comparison (if any exist) of:
Plenue D compared to:
Plenue M
Plenue P1
Onkyo DP-X1
AK120ii
AK Jr.
Thanks.
Has anyone used Aurisonics ASG-2.5's with the Plenue D? I'm looking for a small DAP that can power them without using a separate amp. Also, I would like to know if 200gb micro sd cards will work in the Plenue D without folders missing? Any help would be appreciated.
Yep I have three 2.5s and use them with the PD (with and without an amp).Has anyone used Aurisonics ASG-2.5's with the Plenue D? I'm looking for a small DAP that can power them without using a separate amp. Also, I would like to know if 200gb micro sd cards will work in the Plenue D without folders missing? Any help would be appreciated.
have tried the settings i think its quite loud for me, at power 1
Don't know but I've read some 50/50 about the Onkyo and Pioneer. Since I have ZX2 I won't bother spending that much.
I have been wanting this plenue d for a long time since I like the form factor and most of all the BBE settings that I miss that was on my older plenue z
If level 1 is too loud, I find it more plausible that your unit is defective rather than believing that another human being on this planet has almost Superman hearing and that is so sensitive to sound that low volumes are too loud. If that's the case how do you cope on the subway when a train rushed by, or a traffic noise, or the cinema, even a concert with ear plugs in must be deafening to you? It just doesn't make sense to me.
Ak 100 and AK120II I had and sold. Those AKs EQ are very bad and the 240 is equally bad. Onkyo has a clinical bright sound signature but I didnt use its EQ.So the Onkyo didn't impress you? It's supposed to be the hottest thing on the market now from all I read. The AK 300 also.
