Beaucoup, beuno, bene
you forgot portuguese BOM but beacoup is not equal to bueno or bene
Doesn't it mean alot or something?
excusez moi
This all started i think by me misspelling muah, or a french kiss sound for my thoughts of TT and gsx mk2 powering hd800S, sorry for the digression.
excusez moi
It would have been really really nice if you had simply explained what your thoughts were. I would still like to know, if you have the time.
No thats not the case here. The toslink connection lies too deep in the chassi. And the hole is to narrow for my supra cable to connect. The including toslink cable was a lot thiner at the edges so it did reach in to connect.It might just be that the toslink cable you have has a large headed plug on it. I recently found a toslink plug with an oversize head that would not fit in the recessed connection in a different DAC. Often the plugs are plastic and it's possible to reduce the outer casing diameter without compromising the innerds of the plug.
Pic of the supra https://goo.gl/images/GBICpD
https://goo.gl/images/w6iSgQ yeah you can see it here to the far right clearly here how it should not be with the toslink connection.
And here correct https://goo.gl/images/pg92PW
I wouldent blame the cables.It's not just the Hugo that falls foul of the (stupidly?) oversized toslink plug heads. My Dave also dislikes them and my the hobby knife has had to be used on more than one occasion to make them fit the Dave.
Quality cables are usually thick, maybe because of sheilding from outside interference.No, I blame the stupid people who buy the stupid cables (including me). The oversize plug heads bring nothing to the party apart from making the cables too clunky for easy normal use. Obviously in an ideal world the recessed hole for the toslink connection would be bigger but its not a big deal for me. Nice to see the flush one on Hugo2 though. And don't get me started on stupid foo type mains connection plugs!
