Yes its black maybe a wrongly manufactured unit then? I have only tried using a toslink cable as its the main socket i will use. And 2 rcas that fitted fine. And from the looks of it i dont think i will have any problem with other connections either.None of the older first models were black. If it's black, it's of the newer case design.
Chord Hugo
- Thread starter harmonix
Triode User
Member of the Trade: WAVE High Fidelity
It might just be that the toslink cable you have has a large headed plug on it. I recently found a toslink plug with an oversize head that would not fit in the recessed connection in a different DAC. Often the plugs are plastic and it's possible to reduce the outer casing diameter without compromising the innerds of the plug.
Hooster
- Nov 4, 2010
Am I the only one to find your repetitive indignant attitude rather unhelpful?
I have my moral standard and you have yours.
JaZZ
Mine is an older model and black. Small holes and reversed USB socket. Bought it at a time when the newer model was out since quite a while. No problem with it save for the need for some carving work (on the plug) to make an RCA plug fit.
Received mine today. I'm really curious. I sold the mojo to buy an hugo.
The mojo changed my opinion about music after many years with traditional amplifiers, dac and cd-players. I hope hugo better
Whazzzup
It is but TT and hd800S even more so and through in gsx mk2 and moi.
Sorry but i don't understand your post about gsx and moi
I have no interest on hd-800. I had two in the past. Of course if i had money, i buy a dave LOL
Rearwing
- May 9, 2012
I hope that you enjoy the Hugo, in my opinion it is more analytical than the Mojo and sounds to have more range. I am tempted by the Hugo2, but at the moment, I am not sure that my age limited ears will be able to appreciate the uplift.
I recommend the case if you intend to use it as a portable device, it certainly protects and in my case holds my AK100 as transport.
i received a case too but i will use at home. if i like, in the future an hugo tt with ttoby would be a next step
Rearwing
- May 9, 2012
I would like to go that one day as well, but I'm not sure that I will get there! Having said that, I am very pleased with the Hugo especially with the Sys optical cable that works so well with the AK.
Enjoy!
uzi2
- Sep 27, 2013
Mine is black with the expanded holes, but reversed USB sockets. I thought the revised case design was made quite a while before the black option was available and only applied to the very first batch. It's all here buried somewhere in this thread...
This is the first post I could find in the thread of the revised chassis and this is the original
See page #632 for a discussion on the USB orientation.
Hooster
- Nov 4, 2010
Just out of curiosity, what is it about the TToby that makes it better then other amplifiers at the same price level?
Hooster
- Nov 4, 2010
Would you mind posting in English?
i don´t know but fit perfectly the hugo TT in a small dimension
Whazzzup
Beaucoup, beuno, bene
