djmakemynight
- Jun 22, 2016
It is quite sad. Was looking forward to the Easy Pro 6 reviews..
D2 with leather case has arrived I have not taken some pics od mine yet.
my first impression, the brief comparison D2 + black filter with 808, D2 is more colorful sound than 808. Although it is hard to compare the size of soundstage, two is siliar size with 808. Perhaps the D2 soundstage will grow more expand by burning. I keep comparing with 808, earbuds Tomahawk and Piston2
Those who are receiving their shipments via dhl...
Do they have to pay any customs..?
Thanks
Vishal Kumar.
Haha why are there many D2 arriving today? I also just got D2 from FedEx while ago. My current headphones are IE80 and HD650, so you can tell that I prefer warm, laidback sound. I tried the black filter, it's not as bright as I think, no siblance, but it's not my taste. Green filter, the mid is recessed too much, not my taste either. I like the white filter most. Here is some comparision to my IE80 (note that I'm a warm lover):
- IE80 emphasizes low, midbass, mid while D2 emphasizes low, mid and high. D2 high is not as much as ATH CKR9 (which is said to be balanced), but it's noticable to me. There is no siblance at all, but there are sparkles which I never hear from IE80 or HD650. As a result, I have to lower the voume compared to IE80. The low bass is comparable to IE80, not as tight and hard as CKR9 (which I think better in technical, worse in musical). Mid bass is clean, not too overpower as IE80. D2 is not as balance/analytical compared to HD598, Havi B3 or CKR9, it's a bit warmer. Therefore, I found D2 sound hifi, exciting, make me concentrate to music and a clear upgrade to CKR9, while IE80 is much more relaxing, easy to listen and sleep. D2 is all-arounder (though I hope it can tame the sparkle so I can turn up the volume) for critical listening, though I may reach out to IE80 more because I usually listen while doing other things. It's impossible to concentrate on work with D2.
- D2 cable is very good but it's thick and heavy, so I replaced it with LZ A3 cable. I don't see much changes (come on, I can't distinguish DACs unfortunately). D2 is heavy, good build quality, but due to matte metal case it sometimes hurt my ears while adjusting. In this regard, IE80 is still the most comfortable IEM I've ever used.
This is my impression after open, I don't think it can change after burn in, but let's see.
Thanks for the review. Ignoring sound signature difference, how does the D2 compare to B3 Pro 1 in fidelity & details? Similar or different league?
Wow cool Rose
I have the Havi B3 and they have a wider and more spacious Soundstage but D2 has wide as well. The bass though is
so much better from the d2
Thanks, what about sound refinement? My Easy UES (dual dynamic) sound pretty average detail-wide (even with my EQ correction), so I was worried about the B3 Pro 1 as it's also dual dynamic right? I can get a good local deal on them, but need a good step up from the Easy. It's either those or a D2 (eventually).
