Chinese / Asian Brand Info Thread (Headphones, IEMs, Amps, DACs)
Status
Not open for further replies.
Jun 14, 2016 at 8:50 AM Post #29,463 of 35,472
How is the impression?
He doesn't have it yet.
 2 more days.
Jun 14, 2016 at 8:58 AM Post #29,464 of 35,472
I got the 3 BA + 1 DD. I should have it in 2 days time. I got the dark wood with blue cables
Nice Riisalat, eagerly awaiting your impressions
Jun 14, 2016 at 9:53 AM Post #29,468 of 35,472
Anyone have suggestions for some cheap (sub $20) IEMs that are good for running?
I would recommend you spend the extra few dollars and get the Alpha and Delta D2.
If not, get a pair of cogoo T02. You can find them on Aliexpress for like seven dollars. They aren't going to give you the ultimate audio fidelity experience, but they sound good enough that you won't want to take them off. They are a fun little beater pair that works for sports earphones.
Jun 14, 2016 at 9:55 AM Post #29,469 of 35,472
I absolutely love my Cosonic W1 Sports myself, unbelievable for $7.56!
Good suggestions from Crabby and Vince as well
Jun 14, 2016 at 10:24 AM Post #29,471 of 35,472
Jun 14, 2016 at 11:01 AM Post #29,473 of 35,472
Thanks for the suggestions.
They are for my wife. I don't even know if she would like IEMs to run in but I thought it would be worth a try.
I'll probably start with the Cosonic W1 Sports then maybe if she likes those try out Alpha and Delta D2 or maybe get her a set of the Fostex TE-02s.
Jun 14, 2016 at 11:23 AM Post #29,475 of 35,472
  For others with the QKZ W1 Pro, do you find it detaches from the cable easily?  Or am I just the "lucky one"
Yes, the cables do come off easily. I tried it last night to see if they were compatible with the Hisenior TD1. Cables slid right off the W1. With the Hisenior however I have to use a lot of force and always worry I'm going to break them in the process. BTW the cables are not interchangeable between the two so either one or both of them uses a proprietary connection.
Status
