Saoshyant
HLSX metal and wood are also the same housing as Bettes
Yep, so that makes at least 3 companies using the same housings. I know I read about the wooden Nouske a couple months ago, but can't remember where.
colourfly c10. need impressions on this dap
I bought from Penon the Macaw T800 and teh Macaw T100 with the charging pouch: i'm still waiting for them, but they have with bluetooth 4.1 and APT-X reading the description.
remember the new musicmaker i talked about, apparently it wont be as cheap as maple or TW1, its listed as 299 yuan on taibao so should be arnd 45$+-... hck said will upload on their store, easy said abt the same thing but he need to check on the cable (the small spike cable in photo at taobao do look un"musicmaker" like looks so rubbery)..Ok, Easy is on his stuff right now with my order for my coworker of the Joyroom E107. Ordered Thursday and its already Processed through Shenzen
always on the hunt for bothOops upgraded from iem to dap already
Guys, Do you use any of these methods to burn in your jewelry?
Stereophile's Test CD
CASCADE Noise™ Burn-in CD
IsoTek Burn-In CD
JLab_burn_in_file
XLO & Reference Recordings Test And Burn-In CD
Pink noise + sinelog2
XLO and J Lab
How much did you pay? Do you have a link? Looking forward to your impressions!
This is the BK35. They no longer produces BK33, BK35 is an upgrade over 33. So guys, BK35 is the official model/name for wooden hlsx.
The "i.VALUX Hybrid 10mm Dynamic Balanced Armature (BA) Dual-Driver In Ear Monitors IEMS Wood Noise-isolating HI-FI Headphones" arrived early last week. They now have over 100 hours of run on them.
Since I have the "i.VALUX Hybrid 10mm Dynamic Balanced Armature (BA) Dual-Driver In Ear Monitors Metal", I had to compare them.
First the description of the wood version by BloodyPenguin describes how I hear them
"Sound Quality:
I expected these, being made out of wood to have a warm signature. Though right away
I noticed that they had a whiff of coolness to them. Crystal Clear cross all frequencies.
Instrument Separation is outstanding; I'm guessing this is due to the dual drivers. It is easy
to drive the Bette 10MM, either through a phone or something more powerful. Isolation is good,
easily blocking unwanted outside noise. Because of good ventilation, these have absolutely no driver flex.
Sound signature can be described as a wide U shape. An ever-so slight emphasis on the lows and highs.
Soundstage is neither big or small, Goldilocks would be pleased.
Bass present, but does not overpower in any form. These are not for bass lovers.
Mids are clear and focused, though might be considered the tiniest amount recessed.
Highs are surprisingly crystal clear though borderline sibilant at times."
However, when compared to the metal 10mm version the woodies are more full in the bass and mids. At first the highs seem rolled off vs the metals but, they are really basically the same. The fullness just recesses them somewhat.
The metals come off as more delicate and airier, with bass there when in the recording but not emphasized. Maybe overall more balanced.
The best part is that I got lost enjoying the music with either set. Without direct back and forth either one is very enjoyable.
I still plan to gift the i. Valux 10mm metals to my son and keep these and the HLSX-- 808.
IMHO & YMMV,
r2
Good to know....thanks 'chongjc'!
Thanks for letting us know more details on the wooden ones. I might get a pair in the near future.
