Inszy
- Jan 1, 2014
They say TS662 are the worst of all Takstar.
Quote from penaudio regarding my problem with the HAVI-B3 Pro mark I
"have many customer have this problem.
well. it caused your dirty plug.
would you please try to cleaning the plug?
and,
please don't make the sound too loud when you burn the earphone,
you have to progressive when listening music,
Do not start to open very loud sound.
Also try not to burn too long time.
Try to start listening to softer music
anyway, hope you can try it and please don't worry.
if you earphone really have problem we will resolve it for you"
1st ...the plugs, the jack and obviously my ears are clean and cerumen free (earwax)
do I really have to burn in these IEM? never heard that before, even my cheap Galaxy S4 OEM Headset sounds better right now..
Bad luck...![]()
But Bigbargainonline (penonaudio) have 1 year guarantee. I think they will resolve the problem...
Please inform us about their solution.
They replied within like 30 minutes!
I checked now further with other headphones.. but the left earpiece is still bad... I dont know what went wrong? I never overpowered that little thing, it first started ok, but I was just listening to light classical stuff, switched to R&B and Rap.. (without any additional Head-Amping) and had crazy distortion on left piece, now the even the bass is muddy... switched back to my samsung galaxy s4 original manufacturer headset and clear as usual..
I will send them back, and I dont know what I should do know??
a. ) Get a 1:1 replacement
b. ) Get the amount I paided (minus shipping) credited for ANOTHER headphone penaudio sells
Want I want is a IEM: easy listening, at least dual drivers > hybrid, or just like the havi, or even just dual balanced armature.. my pricerange is ~100USD
Any suggestions?
The Drama is smoother, easier to listen, warm tilted. The Dolphin is more boosted mid and treble wise, yet also has great bass too. I really like them both, despite neither really being good for Studio Monitor use. Then again, the M50 was called a "studio monitor", and those things are far from it.
Are you saying that both are not as good as M50, which is similar in price?
Any suggestions?
From all the reviews about them (and personal communication) I see no reason for "not to order" another Havi. There seems to be no equal at that price point... (But I have not received mine yet, thoughts from others).
You heard them for sometime and liked the sound (before everything went bad), don't you?
guys i'm not really much of an audiophile and tend to only splash out once a year on new headphones, it would be great if you could share a bit of advice.
I'm thinking of getting the bass colours for use in the gym, if they are pretty hard hitting (currently have brainwavz deltas and they don't hit the spot)
then some new cans for use at home when i want a bit of a more refined listen - would either the dolphins or drama be good for this?
When I'm at home i generally listen to hip hop and chilled electronic music (chet faker, bonobo, etc.)
What he says is that the Don Scorpion's are not studio monitors (for professional use) and neither is M50.
Comparision with M50 would be interesting though.
Sounds to me that you want to maximize your bass intake, so Bass Colours and Drama would be a good choice.
