LRManenti
- Feb 16, 2015
Same one for less: http://m.aliexpress.com/item/681953244.html
They are charging 36 dollars to ship to brazil
Takstar HI2050I've got a $28 refund and I'm trying to find a good headphone for something close to this price, or even a little higher. I was looking for a superlux or a takstar. Can someone give me suggestions? Are they worth it or are there better options?
Hey guys, today my KSC75 have died, apparently the problem is the driver itself and not the cable, thats really odd.
So, I need your help for my next pair of headphones, the only thing that I really want is soundstage and more soundstage the thing is that my budget is really low ~20$ so probably I´ll pick a new pair of KSC75 or something else.
So far I've been considering the Tascam TH02s and Takstar HD2000s.
I really appreciate any help you can provide.
Hey Guys today while browsing through ebay for headphones I found this which looks exactly like the ISK HP-580 design wise and spec wise and ordered a pair but the only difference is that this have 50 mm Ferrite Drivers instead of the 50 mm Neodymium Drivers that the ISK HP-580 have. Here is the link to the manufacture's website: http://dpstage.com/headphones/dps351-headphones.html but this manufacture is based in Australia. Here is a link to the ebay listing: http://www.ebay.com.au/itm/321429462484?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Here is a pic:
So what do you Headfiers think about the sound quality between Ferrite and Neodymium Drivers?
BTW will post a review on the headphones shown in the pic above once i receive them and give MHO on these in comparison with the ISK HP-580 which i also happen to have a pair lying around.
These look like a rebranded Superlux HD681
I personally don't have any experience with Ferrite drivers, so i can't speculate.
Looking forward for your review though, these cans seem interesting.
I know but this have 50mm Ferrite Drivers and what do you think about Ferrite Drivers in comparison with Neodymium Drivers in terms of sound quality and reproduction?
Neodymium magnets are more powerful than Ferrite ones. So for equal magnetic intensity a Ferrite tends to be heavier and larger than Neodymium one.
I'd assume in this case that the 50mm Ferrite driver would be less powerful (and precise) than the Neodymium driver of same size. It'd be better choice to opt for Neodymium.
Well in this forum discussion: http://forums.anandtech.com/showthread.php?t=2209668 about Ferrite or Neodymium one user by the name of BTA said that "It doesn't matter. Whatever fits what that manufacturer was trying to achieve with the specific driver design." So what is your take on this opinion?
There can be two aspects of using Ferrite. One is the way BTA has said. In that case the designer might have found that he can achieve better sound by using ferrite magnet. Other case is simply cost cutting. I don't really know what may be the reason behind since I haven't used either of the headphones.
I'd just put my 2 cents over cost cutting but it may well be the first case as well so no conclusions!
