guicnovaes
Some Updates About the OS V3:HiFi Boy OS V3 delivered today.
First impressions:
Superb build quality, with the same acrylic resin used on Custom IEMs. Flexible cable, with zero microphonics.
Great natural, smooth, musical sound. Absolutely non-fatiguing, no problems with sibilance/harshness. Very good for long-listening sessions.
I will post a complete review soon.
The more a listen to it, more I make sure that the sound is exactly what I described.
I listened to my cousin's OS V3 last year, side by side with a Westone UM PRO 50. I found OS V3 better overall. This was what motivated me to buy it (months later).
Until then, I had never tested any IEM that had a Frequency Curve similar to the Harman Target. I even doubted the Harman Target was that good...
1 month ago, I received the Sony Mh1c, which has a frequency curve very similar to Harman and had been listening to it daily. Since yesterday, I've been comparing it to OS V3 and my conclusion is that Harman Target is REAL.
The sony has more realistic, more faithful, mids than OS V3. The highs are a little bit more elevated, but are also more realistics.
If I found the OS V3 better than the UM PRO 50 and found the MH1C better than the OS V3, then, obviously, I found the MH1C better than the Westone UM PRO 50 ... (USD $ 15 vs 650).
A Tanchjim Cora is coming in the next two weeks. Knowing that it follows the Harman Target and having the Frequency Curve almost identical to that of the Moondrop Kanas Pro, I'm guessing it's going to be better than Sony.
It is gonna be difficult, from now on, to I Buy an IEM that does not follow the Harman Target or something like the Etymotic's Frequency Curve.
