I heard one reviewer say the T2's sound like toys compared to the T3.
they're in the same level of SQ, just different signsture. T3 treble is smoother, while the T2 is more raspy. I'd take the T2 any day of the week
V1 or v2 or both?I agree, but don't forget the KZ ED9!
I think it's V2 because it came in a white KZ standard box not the shield shape plastic one.V1 or v2 or both?
Thank you, kind sir!ebay sellers that sell original mh755 : Kanoya,electronhero,bestneed_3c,macpart168,xirui_01
just do not buy black color, they are mostly fake
Have the T2, use them modded. They are my main IEM at the moment.they're in the same level of SQ, just different signsture. T3 treble is smoother, while the T2 is more raspy. I'd take the T2 any day of the week
Thanks a lot.
This is the cable I am using on my NX7. Silver coated crystal copper cable. This photo is the NiceHCK version but if you look around on aliexpress you can get this exact cable on a competing site for $45. You can guess what the competing site is. This is one of the better quality cables at under $50. I am using JVC spiral dot tips which opens up the sound of the NX7. I also use a pure silver cable on the NX7 when I want a bit more analytical type tuning on the NX7. This copper cable I pictured gives more fuller bass to mid note which has the added affect of taming a bit of the highs on the NX7 giving it a much more balanced take on the sound. I still get the outstanding detailed sound but tilted to be more musical due to this cable. Bass is outstanding using this cable. If you thought you need a bit more in the way of bass out of the NX7. Try out this cable.
did you realize that P20 output impedance is 47ohms?And now - I've assembled a 4-Pin XLR Plug -to- 2.5mm TRRS Jack Adapter (tested as wired correctly, by using the tests on AudioCheck.net) - so the NX7 are now connected to the Balanced output of my P20.
Also, I've been trying some tip rolling, and as long as I get a good seal in my ears, there's plenty of Bass - and the Midrange & Treble levels can be varied by using wider or narrower bore tips.
EDIT: Adding photos.
sure you'll get noticeable tonality alteration when using any iem with BAs inside, compared with your other low output impedance sources
yes. 1/8 rule and damping factor also suggest lower output impedance. i emphasized BA iems because he was telling about NX7..Other than planars, dynamic do get affected by high output impedances too, not just BA's.
Ideally, Output Impedance is less than 1/8 the driven impedance. If the difference is bigger ( example 1/10, 1/20), usually, its better.
i wouldn't necessarily say the 9t is "better" than the kpe, but they both do the same general signature--the kpe is probably the more audiophile sounding in the sense of accuracy and coherence, but the 9t has more bass thump and possibly more treble detail in certain filter combos. the 9t is also much better value at 1/2 the price--also check out the simgot en700 bass@loomisjohnson the toneking ninetail better for you compared to kpe? can you explain why detailed?
