Yes! ...Definitely the **** will please you for the price versus sound, quality, and overall value! Sorry for your lost of the C10, though you should be fine with either the **** or C10.
Here's a run down on both of them from my profile homepage...
RATING CHART Highest Rating Possible: 10
PSR = PRO SOUND RATING
SS = SOUND SIGNATURE
BQ = BUILD QUALITY
OP = OVERALL PACKAGE
OV = OVERALL VALUE
NOTE: Top position will go towards PRO SOUND RATING (PSR)
HYBRIDS DD + Piezo Tweeter(s) (+ BA Armature(s)):
HD large drivers + BA armature + Piezo Ceramic Drivers per side
PSR: 10
SS: Luscious with excellent transparency and hi-end details/micro-details, life-like MID's, and fast textured sub-bass/bass with excellent soundstage and resolution!
BQ: 9
OP: 8
OV: 10
COMMENTS: Interestingly, it's "neutral" when used with its default and packaged ear tips, but easily can be converted to "balanced" when used with aftermarket silicone ear tips! Though, they actually get my top rating of 10 PSR for its neutral + natural sound signature!
HYBRIDS DD + BA Armature(s):
CCA C10
HD Driver + 4 BA Drive Units per side with CCA exclusive crossover network circuitry
PSR: 10
SS: Premium sound quality! -deep punchy sub-bass, excellent clean vocals, silky pristine hi-end details with solid and superior soundstage and resolution!
BQ: 10
OP: 7
OV: 10
COMMENTS: Give them at least 20 hours of playtime and they'll blossom to grant you supremacy at such a low price over more expensive models!...These are definitely a perfect 10 in PSR!
To check out more? Go to my profile homepage...
https://www.head-fi.org/members/1clearhead.363120/
Hope this helps...
-Clear
