kadas152
The n3 got louder after 10-15h of use. I am now down to -35db for comfortable listening.
The right earpiece has very loud driver flex, the left one none at all
Insertion took some getting used to, it's more of a straight push than the "plug and twist" approach i used for the se215. Pulling the earlobe a bit helps.
theres a little post-preasure-sensation from the shell when removing the n3 after longer use, but i don't notice it much while wearing them. se215 is definetly more comfortable
I agree that it needs some time to get used to and find right method to put them on.
Twisting N3s can be actually quite painful for me. I’ve found out that best way for me is to push the lower part in while slightly pulling upper part. Like twisting slightly but from down up. And when nozzle is seated properly in your ear than pushing upper part slightly to get perfect fit.
thanks for the pics.
Unique shape, wonder about comfort...
About sound, i never have piezo driver, but perhaps it open up after burn in and if its the one responsible for higher frequencies it will sure became louder....any change in overall sound or exact same...from what you remeber??
And about Now sound, how would you describe it?
Comfort is actually very good once you find right way to put them on as mentioned above. I barely feel them and there are no hot spots so far.
You can check my first impressions in other chifi thread: https://www.head-fi.org/threads/chi...hones-and-iems.820747/page-1478#post-14791798
I’ve taken them out of burn-in rig for a spin today and they seem to balance and smoothen slightly more. Currently cca 30hours in and I am actually starting to like them. Detailed sound with good instrument separation and no harshness. Soundstage seems to be good too. Will have to tip roll more but so far they’re definitely not bad.
