Cayin N7: A Voyager of Unexplored Frontier
May 4, 2023 at 3:14 PM Post #1,066 of 2,072
Nope, as said previously on iPhone (at least for me) pressing any of the volume button of the phone when using HibyCast app has for direct effect to make the N7 volume jump to iPhone‘s own volume level.
You can see the problem here, the volume goes from 30 to 90 with only 1 click on the volume button of the phone :
This is also happened with me using Android
Quite dangerous
We have discussed the volume control problem with HiBy and urged them to rectify the volume control problem promptly. Several options were discussed but these involved low-level programming, it will take a while before they can develop the coding and conduct all the testing, a lot longer than other applications or UI-based bug fixing. Will keep everyone informed when we have a solution.
http://en.cayin.cn/
May 4, 2023 at 3:26 PM Post #1,067 of 2,072
It seems you’re right @FooFighter
44.1 kHz on Qobuz app but 48 kHz showing on top of N7’s screen :
@Andykong any target date for a fix?
Is it only coincidence or is the same software team developing firmware for Hiby and Cayin as the same bug is there too on RS8?
We have repeated the problem in our lab and registered the bug officially. We need to find out the root cause of the discrepancy in sampling frequency.
We are confident that this will be fixed promptly, but sorry, there is no target date for a fix. I hope the process is as simple as that.
I can't comment on the bug-fix process of DAP from another manufacturer.
http://en.cayin.cn/
May 4, 2023 at 3:38 PM Post #1,068 of 2,072
Thx Andy
Seems very likely the same bug is present in both firmwares of Cayin and Hiby
May 4, 2023 at 3:47 PM Post #1,069 of 2,072
Thanks @Andykong for the N7 Tour.
I received my unit this morning and have had a wonderful time so far
May 5, 2023 at 12:12 PM Post #1,070 of 2,072
http://en.cayin.cn/
May 5, 2023 at 1:22 PM Post #1,071 of 2,072
May 5, 2023 at 1:32 PM Post #1,072 of 2,072
May 6, 2023 at 6:25 PM Post #1,074 of 2,072
Just received N7, which music player do you guy prefer, Cayin or Hiby?
May 6, 2023 at 6:33 PM Post #1,075 of 2,072
You can use either or.
Cayin Music Player is lightweight version of HiBy Music Player and both share identical decoding capability including local MQA playback. The included HiBy Music Player is the Pro Edition and features HiBy's awesome MSEB and Tidal interface.
Also with HiBy Music, you can also transfer music via WiFi to your N7 – either internal or external storage.
May 8, 2023 at 2:16 AM Post #1,076 of 2,072
Question for other owners (I've already asked Andy about this): Has anyone managed to use their N7 as a USB DAC? I can't even get any computer or device to see the N7, using any the numerous cables or set-ups I have here. Resetting the system and re-installing firmware has made no difference. I suspect my unit may be faulty.
May 8, 2023 at 2:52 AM Post #1,077 of 2,072
You might need to install driver into your PC.
May 8, 2023 at 3:40 AM Post #1,078 of 2,072
Did you install Cayins USB driver?
https://en.cayin.cn/drive/9/18/568.html
May 8, 2023 at 1:40 PM Post #1,079 of 2,072
I just did with Tidal App on Windows, I didn't have to install anything:
When you put the USB cable, have you selected the correct mode on the Cayin N7 ? It should be Audio In :
From this menu :
Tap for more options and then select Audio In :
May 8, 2023 at 3:28 PM Post #1,080 of 2,072
No issues with using N7 as a USB DAC on my MBP M1 Pro 14 and MBP M1 MAX 16 using Apple Music and Tidal. Using Caldigit T4/USB 4 cable from N7 to MBP – USB setting to data / no charging on N7.
There's still a Tidal (desktop and mobile app) still has a hiccup where it takes a split second to unfold MQA – sometimes there's glitch or no sound. They need to kill off MQA faster.
