- Oct 6, 2013
With HibyCast and Volume control, per my test, the behavior is the same between Android (S22, Android 13) and iPhone (XS Max, iOS 16.4.1).
Connection is very easy, N7 already comes pre-installed with HibyCast, just make sure your DAP's fw is up to date. Find and install HibyCast on your smartphone and make sure you are on the same wifi. That is a key since I talked to a few people who were under the impression they can toss N7 into their backpack while connected to headphones and control it remotely when out and about. That's not gonna work, both devices have to be on the same wifi. Then, once you start HibyCast app, it will give you a list of devices on your network with HibyCast to connect to. Tap on the one you want and you have a mirror image of N7 on your phone.
With volume, you have to click on your smartphone volume up/down button and it will bring up the touch-screen volume control of N7. From there, you can either adjust the volume by touch screen sliding up/down or you can also adjust it by pressing volume button on your phone up/down. That latter one is kind of dangerous due to coarse adjustment in bigger steps, so I would NOT recommend it. And, as you are changing the volume from your phone using physical buttons it doesn't mirror on your touch screen volume change, only in notification bar. So, click on a volume button of your phone, use volume down so you don't make it louder, and then use touch screen interface for a fine adjustment of the volume.
