@Andykong Any chance of adding a feature whereby you can disable the pulsing white home button whilst charging?
Also, how is the scheduled power off supposed to work? I set it to 10 (which I’m assuming is minutes), and left the player untouched (and not playing), for 10 minutes at which point I’d expect it to power off? It didn’t so I’m just wondering if it’s a defect or I’ve misunderstood the feature?
Thanks
It is not defeated, the background task from Google Service and maybe third party app you have installed has stopped the player to enter idle condition.
We have a feature called idle shutdown in our previous Android DAP N5ii/N5iiS, if you turn it on and set it to, for example, 15 minutes, it will power off the DAP when the DAP entered idle status for 15 minutes continuously. It works very well on domestic version firmware but the result is mixed with International firmware and Google Service is root of all these problem. The Android 8.1 is even worst when come to control the Google Service alerts and Comm calls. Google keep "looking for" status update (or should I said sending our request for update) in Oreo and stop the device from entering idle status.
We spend sometime on this topic try to rebuild our Idle Shutdown feature, failed for the moment and we'll revisit the topic sometime later, there are other bugs and requirements that deserve a higher priority right now, hopefully a new firmware will release very soon.
Stay updated on Cayin at their sponsor profile on Head-Fi.
