Yeah for sure .. but I asked myself , how someone could not hear that ..If he didn't exp it, its his benefit...
I am like u, listening via CDM or CV5, I exp quite hiss
Campfire - Solaris
- Thread starter KB
And how different must they hear the iem itself ? When someone is unable to hear this kind of hiss .. Are they unable to hear this kind of frequency?
I will have the Kann Cube in the next couple of days and am looking forward to pairing the Solaris. It has been a while since I have had an A&K. I had the Kann briefly, but prior was the 100 ii and 120 ii.
It should be an interesting comparison between the QA361 and Cube even though the Solaris is so easy to drive.
tracyca
- Nov 5, 2012
Not with my unit or pair , maybe the tubes I changed out. But the hiss is not noticeable with the music playing.what ? ALO CDM with Solaris ? its a waterfall hiss even in low gain
MarkF786
I have tested the Mojo a friend let me use his and it is really good but I don't like the look of it, was hoping the Q5 or xdsd would be as good or better. Thanks for the input.
I have both the Mojo and the Q5 and I prefer the Q5 in most regards. I rarely use the Mojo anymore.
I had also considered the xDSD but ended up going with the Q5 instead. What I didn’t like about the xDSD: reports of Bluetooth problems, the non-standard balanced output jack size, it being a fingerprint magnet. Also, what I liked about the Q5 was the additional flexibility with swappable amp modules.
You way wish to wait for the Q5S, available in August, or get a deal on the current model.
I am most likely going for the iFi Micro iDSD Black Label. I'm not sure how much better the Q5S will be in terms of sound quality in comparison.
tracyca
- Nov 5, 2012
Again been at it all morning and I still have no crazy hiss, with my CDM. I tied with my IfI imatch and without it and it sounds around the same. Maybe it’s my tong sol 6111 tubes, I have not change tubes yet. I have Andromeda also and no hiss with my unit.
maybe , i have the stock tubes....Again been at it all morning and I still have no crazy hiss, with my CDM. I tied with my IfI imatch and without it and it sounds around the same. Maybe it’s my tong sol 6111 tubes, I have not change tubes yet. I have Andromeda also and no hiss with my unit.
tracyca
- Nov 5, 2012
Changed the tubes to some rca 6021 and boy the hiss is present. Understand what your saying now.
now you understand why i could not understand that someone could not hear thatChanged the tubes to some rca 6021 and boy the hiss is present. Understand what your saying now.
Could you measure what is the inner bore diameter for Size M ?Posted in the Andromeda thread and probably relevant here.
@audio123
Physical differences are the inner core/stem is color coded on the ++.
It also seems to be slightly firmer and and have a better lip to grip the IEM nozzle for a better seal.
The ++ outer is more a smoother matt and soft feeling (but still firm) finish, whilst the original has a more shiny harder surface.
The original has good body when a correct seal is achieved with a slight V.
The ++ has more mids.
@audio123 care to weigh in?
As can be seen above the size is generally the same. The bore opening is generally the same if not identical.
Above a comparison to the (original) Andromeda Silicone tips - not sure if they have changed. And the original JVC spiral Dots.
alrd got it, inner bore around 6.5 - 7 mm.Could you measure what is the inner bore diameter for Size M ?
Is there a way to get large spiral dot ++ shipped to Canada?
ebay ? Or not ?Is there a way to get large spiral dot ++ shipped to Canada?
Super expensive everywhere I have seen them and I am in the States. I will wait a bit longer.Is there a way to get large spiral dot ++ shipped to Canada?
Total: 14 (members: 0, guests: 14)
