moodyrn
- Nov 15, 2008
Hrt music streamer, centrance dac port, dragon fly to name a few. Dacs have come a long way the past few years. 300.00 can buy you what 1000.00 use to buy you five years ago.
I don't want to get off topic, but what is a good USB DAC only(no amp) for about $200-$300? I don't need anything too crazy, just better than the E17 at a good price.
To be fair there's not many 'bad' dacs these days, as long as you aren't using your computer soundcard or ipod direct. The very cheap original Vdac is still my recommendation for anyone's first. Also, most of these vintage amps, particularly the older ones (late 60's early 70's) colour the sound to a degree that if you were to buy an uber TOTL dac then you would be wasting your money imo. I love what these old amps do to the music, they present it in such an organic -musical way. And so as long as you have a half decent dac then it should pair well with most of these old amps.
of course the SX 1980 and the like may be able to show what a TOTL dac can do... But unfortunately I don't have one.
(there must be something in the air at the moment... I had just finished changing a few amps round (as I tend to do... All of the time) and while I was pushing my cabinet back I heard a big bang. I also seen a flash. Smelled smoke too. The trip switch had been flipped and so I went to flip it back on. I moved my cabinet forward and looked for the damage... I churlishly bent down and followed my nose to were the burning smell was coming from. It was coming from the adapter that is connected to my Marantz 2220. The marantz hadn't been switched on, but the plug must have been forced out a little, so when I pushed the cabinet back it must have caused a short? Not sure how... but anyway's.. Phewwwee..! That was a close one. All my amps still working and the only damage was to my underpants
Whew!! Glad that there was no real trouble. I bought a used high end power cable once. Went to plug it in and BANG...loud pop. The previous owner had covered up some damage to the cable with heat shrink tubing. I guess that it arced. I was plugging it into my new lyr which was brand new. Scared the bejezzus out of me.
Which HRT music streamer do you recommend? I'm seeing quite a few different models. I would want something transparent, nothing with extra bass, or nothing that sounds cold. Just transparent and accurate. 99% of my music is either 256k AAC from iTunes or 320k MP3 from MOG. I have nothing in any higher bitrate, so a DAC that works with formats higher than 96/24 is useless to me.
I have to disagree with that statement. Vintage gear is just like modern gear in a sense the higher up the chain you get, the better they scale with other equipement. You would never spend a grand on a dac for a budget modern amp, just like you wouldn't do that for a lower end vintage model. But I have a few dacs ranging from 500.00 to 1000.00 and all of my totl vintage amps improved a great deal going from my 500.00 dac to my 1000.00 one. There's even a noticeable difference between my 800.00 dac and my 1000.00 dac. As good as the sx6x0, 7x0, 8x0 are, the sx10x0 and above are just another league as I'm sure Matt can attest to owning both the 650 and 1280.
There are many budget gems out there that can keep up with many mid to upper mid tier modern headphone amps. But when you step up to the high end range of vintage gear the game changes. With most of the totl vintage gear I've owned, the transparency, refinement, and extension are right there with the best modern amps.
They all have received good reviews. The musical fidelity vdac's are also a good recommendation. In that price class, I've personally owned the music streamer II+, vdac II and they both were good. I also owned a music streamer pro which is a bit better than the II+ to my ears. Although the retail is at 500.00, you can get them cheaper than the II+ now since it's been replaced making it an excellent value, but it can be very fussy with usb cables because of the power requirements. So for that reason I would recommend the II+ for that reason.
But in this day and time, given the advances in dac design and chips, most all of them in that price range are going to be good. Even the odac at much less than 200.00 have many, many fans.
So the Odac should sound noticeably better than the E17?
Originally Posted by moodyrn /img/forum/go_quote.gif
As good as the sx6x0, 7x0, 8x0 are, the sx10x0 and above are just in another league as I'm sure Matt can attest to owning both the 650 and 1280.
$450 for a SX-1280 in good condition is a very good deal. These days they mostly go for much, much more.
I wish I could find deals like that here in Canadia. I paid a touch over 1000 for my Pioneer SX-5590
