This is a cross post of mine from another forum. Some of it repeats what I said above:
Wow, I can see why people can really get into vintage receivers. The Sansui 5000A sounds great with the Mad Dog 3.2. I wish I had more orthos to try on it. You can tell it's not
quite as clean and flat (FR) as some other amps (dedicated headphone amps or not), but there's still something about it that I really like. It sounds surprisingly clear and detailed, smooth, and powerful. Some people have said it's a warm receiver, but I'm not hearing that so much coming from the Leckerton UHA-6S Mk.II.
Out of curiosity, I took some RightMark measurements of the headphone out. Setup went PC with Auzentech Bravura, line out to the Sansui set at 24/96 with volume set at 4 (I believe the Windows volume controls the output voltage, because music clips after a volume of 50 or so, and 50 was too high for RMAA tests), and the Sansui HPO went to the line-in (set at 24/96, 100 volume) of the Auzentech Bravura using the stock T50RP cable.
More simply: Auzentech Bravura line-out -> Sansui 5000A -> Sansui HPO -> Auzentech Bravura line-in
The receiver is plugged straight into the wall. The PC is plugged into a surge protector that is plugged into the wall just above the receiver.
I know this isn't an ideal measurement setup, but I'm just working with what I have.
The first thing I noticed was that the FR was a bit tilted towards the treble with the tone knobs set at 0 according to RightMark. I had to adjust those to make the FR as flat as I could. The channel balance was also off a little bit, so I had to correct for that (I hope that's not a sign that I need to fix or adjust something in the receiver...it was a 0.2-0.5dB difference). Once I got the settings narrowed down as best as I could, I got the following results:
Overall:
FR:
Noise:
THD:
IMD:
DR:
Crosstalk:
IMD + Noise (Swept):
The FR looks worse that in is. There's some roll off at the top and bottom, but it's still relatively small (see the scale). Some of this is also due to my sound card. You can still hear the small differences in the FR when compared against flatter amps, but on its own is nothing to worry about. I'm guessing some vintage receivers weren't designed to be entirely ruler flat like companies focus on today...? I could be wrong. I messed with the tone knobs for a while and could not get a perfectly flat response. I can, however, get the treble response boosted up a bit from what you see here. My ears just prefer it being toned down a tiny bit.
One thing that I noticed in the measurements was the 60Hz harmonic distortion and noise. I would think I'd hear humming (ground loop?) through the headphones, but they're nearly silent when plugged into the receiver. I get a low amount of hiss if I turn the volume up on the receiver with nothing playing. It could be that the noise and distortion is still too low to really hear, but I'm not sure. Could it be just be a byproduct of how I measured the HPO and not indicative of how a HP would really perform from the receiver? Or perhaps I'd just hear it as less "clarity" in the most heavily affected regions and not necessarily a hum?
Discounting those 60Hz and harmonic spikes, the dynamic range, noise, and THD are at or better than -90dB above 300Hz. I'd say that's pretty good for a 40+ year old receiver! Once you get to the upper mids and treble, it's pretty darn clean. Sounds that way too.
I'd be really curious to see how the Sansui HPO would measure given a proper setup.
All in all, I'm really liking it so far!
