alvincapalad
- Jan 22, 2012
Yes, any 90mm will fit the Pro700Mk2, but you also have to consider the ear opening, as you would like it to be circumaural as possible. The stock pads has a 50mm opening.
regarding the ear cup pads on the PRO700MK2, has anyone used the Beyerdynamic EDT 770 V or EDT 990 S Replacement Ear Pads?
Are the Ultrasone HFI-780 inferior to the HFI-580?
I wonder if anyone can compare the ANV with the MKII?
The sound seems more solid on the PRO700MK2ANV than the regular MK2s, might be something with the aluminum reinforcement in the cups cancelling vibrations, or just be my ears tingling a bit with all those bass.
