tolis626
Glad I could be of help!Hi. I am just in the learning stage and I loved your explanation. Thanks. But I have one question. How does one modify the MSR7 to make it 'wider'?
Well, first off, I'm talking about the original MSR7, not the MSR7b, just so we're clear. Now, you can find details on what I did in the link in my signature. The tl;dr version is that you get a pair of HM5 leather pads, open up your headphones, remove the felt ring that covers a hole in the middle of the headphones, reassemble them WITH CARE and then use the HM5 pads. What caused them to become wider are the bigger pads, probably, but these pads don't work on them at all without modding. Putting HM5 pads on the stock MSR7 was rather unpleasant, as all of the bass vanished and highs became murderous. After doing the felt mod and putting on HM5 pads, the headphones produce what is IMO the perfect amount of bass, with insanely good sub bass and smoother than stock highs.
Now, I don't know if the same can be done on the MSR7b. And even if it can be done, I can't know if it's going to be worth the trouble. What I do know is that I want to get a pair of MSR7b to mess with in the rather near future. Whenever I do, I will make sure to post my findings here, especially if no one else takes the plunge to try modding them first.
