knowhatimean
- Jun 16, 2011
First of all, my other cans are the LCD3f & HD800. I've also recently owned T1 Gen 2 and the LCD2f. I spend most of my time with the LCD3f these days but do shift back to the HD800 every now and then. I am used to a much thicker (those Audeze pads!) & heavier set of cans. I'll not go into sound yet since I don't have enough time with the AD2000. I will say though that the WA22 is obviously complete overkill for these. I run them just fine from my iPhone 6s & Mojo.
What I can say is that unless I change the stock pads on the 2000, I'll not be keeping these. They just don't sit on my bald head at all. They won't necessarily slip and are generally comfortable but I am always having to pay attention and realize that I have headphones on my head that can fall or slip down with any movement. I really don't know what they were thinking with that suspension mechanism.
[/quote]
I don't think I would ever call using an actual "Audio Component" with any headphone, other than the most basic inexpensive (under $50 or so), "Overkill". I have no interest whatsoever in portable music listening.; life's too short to trivialize my music listening time. I'm not that locked into the hierarchy of using only."like" value equipment with other "like" value equipment when it comes to headphone or loudspeakers, simply because they're only transducers.
That being said , I've decided to go in another direction as far as my choosing another pair of headphones go. You are absolutely right about the Audeze pads though (& I'm fairly set on purchasing a set of the Vegan pads
for the "cans" I've turned my attention towards)
I hope the comfort issues work out for you. Though I think you'll be okay with just staying with your other in house cans.
[/quote]
