That cover wont make any significant difference to air flow or temperature IMO unless there are corresponding air holes on the sides or bottom.
Audio-gd Phoenix balanced headphone amp.
- Thread starter Currawong
tim3320070
Kingwa basically told me in so many words that he is doing this as a response to all the talk about his "failed" design technique for heat abatement, but that it is not needed. He wants to please us by responding to any concerns (shipping issues, etc.). I am having mine with a solid top as originally designed. Why would you guys let dust and bugs into the equipment if not needed? Who has had a failure of equipment due to heat- it's all conjecture?
les_garten
- Nov 6, 2008
Previously I shot IR Temps running with the top OFF, pretty much no difference. I don't think it will hurt anything, but all you folks holding your breath, need to breathe!
Originally Posted by IPodPJ /img/forum/go_quote.gif I definitely want him to send me one of those. |
Originally Posted by Skylab /img/forum/go_quote.gif Seems like that cover is a good idea. |
Originally Posted by IPodPJ /img/forum/go_quote.gif Uh, yeah. The amp chassis doesn't need it, but the power supply surely does. |
Originally Posted by tosehee /img/forum/go_quote.gif That cover should be at the top and the bottom as default, IMO. |
Originally Posted by ServinginEcuador /img/forum/go_quote.gif x2, and by that I mean both top and bottom plates would be nice. Send mine with black screws and I'm all over it. |
Originally Posted by Currawong /img/forum/go_quote.gif That cover wont make any difference to air flow or temperature IMO unless there are corresponding air holes on the sides or bottom. |
Originally Posted by seaice /img/forum/go_quote.gif But it is quite sexy to have a winter and summer version, or fully dressed and semi nude, in other words. |
Originally Posted by Currawong /img/forum/go_quote.gif That cover wont make any significant difference to air flow or temperature IMO unless there are corresponding air holes on the sides or bottom. |
tim3320070
Holy crap, thanks for that Les....
IPodPJ
MOT: Bellatone Audio
Caution: Incomplete customer orders
- Apr 17, 2006
How could it not? If there are vents the air will dissipate quicker. Hot air rises.
And even if it didn't make a difference to component longevity, it will be easier for my apartment to cool the hot air that comes out of it since the aluminum block won't be a huge space heater. The chassis shouldn't get as hot if the heat is allowed to rise.
I've tested this with other equipment that has ventilation holes by covering them up and it always gets hotter. I understand that the Phoenix is supposed to act as a giant heat sink, but still....
haloxt
- Sep 26, 2008
Phoenix will always generate the same amount of excess heat when on. If you were to say put a fan directly on top of a phoenix with vents the phoenix will technically become an even greater space heater because the heat is getting out of the phoenix into your room
les_garten
- Nov 6, 2008
I was originally contemplating having mine drilled. I shot temps with the top on and the top off. No difference except for the transistor that has a chimney heat sink in the middle of the Power supply. It dropped a couple degrees, not much.
I let it run 8 hours to warm up with the cover on. Shot temps all around. Then took the top off and came back 8 hours later. Temps were the same. Like I said, other than the pleasingly cosmetic aspects of the slots, the temp won't change with those little slots. That's just Kingwa willing to please everyone. If it had made a difference, mine would have had holes months ago. I got a drill press.
Think about it, he's a talented Engineer winning design competitions. You think he needs us to tell him about heat dissipation? The Phoenix is performing as designed and doing it superbly IMHO.
That was about the time I had discovered I had the ceiling fan off in a small office with a lot of electronic gear producing heat. Once I turned the fan back on, I never thought again about any heat questions. Temp went down quite a bit with just a small amount of air movement. I also have the gear sitting side by side, instead of stacked with the PSU on the bottom.
I would also say if you are going to Kvetch about the heat, you provide an accurate description about the environment and borrow an infrared thermometer. You meaning "Y'all". You can't really guess with your fingers.
Originally Posted by IPodPJ /img/forum/go_quote.gif How could it not? If there are vents the air will dissipate quicker. Hot air rises. And even if it didn't make a difference to component longevity, it will be easier for my apartment to cool the hot air that comes out of it since the aluminum block won't be a huge space heater. The chassis shouldn't get as hot if the heat is allowed to rise. I've tested this with other equipment that has ventilation holes by covering them up and it always gets hotter. I understand that the Phoenix is supposed to act as a giant heat sink, but still.... |
tim3320070
This is the 2nd-3rd time (that I know of) Les has described the lack of change in the temp with and w/o the top. What else do you all need?
Ipod- the amount of heat generated will be the same, slots or no- didn't you take physics? Where do you think it goes?
Pricklely Peete
Franken modder
- Feb 17, 2008
X2
Peete.
Originally Posted by les_garten /img/forum/go_quote.gif Think about it, he's a talented Engineer winning design competitions. You think he needs us to tell him about heat dissipation? The Phoenix is performing as designed and doing it superbly IMHO. |
X2
Peete.
punk_guy182
- Mar 22, 2008
x3
This heat issue is a non-issue. Kingwa has reassured us with his explanation. Let's get on another topic.
Punk.
Punk.
akg702
- May 11, 2009
X4
The heat is not an issue for me, I can put my hands on the top for a long long time ..... but not the bottom. Might be able to cook an eggs at the bottom of the phoenix
scootermafia
MOT: Double Helix Cables
- Nov 24, 2008
is that pic shopped or did you really fry an egg on it...too late to figure it out myself...gaaaa
akg702
- May 11, 2009
I wish it does barbecue ...... photoshop.
Originally Posted by scootermafia /img/forum/go_quote.gif is that pic shopped or did you really fry an egg on it...too late to figure it out myself...gaaaa |
ztsen
- Dec 30, 2008
he just cooked then put it on Phoenix top. That's all.
U need to be very hot to create the burn edge on egg.
