banumh
- Apr 9, 2014
Hello everyone, i think i messed up with ViaDfuTool trying to update my n28 and my pc cant see my DAC at all, its any way to fix that or physical repair its only options, what i should do
You could try disconnecting the USB cable, and then reboot your system, once the computer is fully loaded up re-plug the USB cable back in, and see if Windows picks it up.Hello everyone, i think i messed up with ViaDfuTool trying to update my n28 and my pc cant see my DAC at all, its any way to fix that or physical repair its only options, what i should do
No nothing works, someone told me i need thing called via vinyl and i cant buy it and i need to find official seller or write directly to audio dg, someone know official email of Audio dg or social media where i can tell them about my problem?You could try disconnecting the USB cable, and then reboot your system, once the computer is fully loaded up re-plug the USB cable back in, and see if Windows picks it up.
Do you mean Audio-gd?No nothing works, someone told me i need thing called via vinyl and i cant buy it and i need to find official seller or write directly to audio dg, someone know official email of Audio dg or social media where i can tell them about my problem?
