Shahrose
I'll be interested in reading your review slim.Where will you post it?
x2.
Loss of bit-perfect is pretty common in computers because of software quirks or hidden sound processing.
Hi upstateguy,
I will probably post my review in a separate thread. My "usb to spdif shoot out thread" has been closed for an unknown reason so I might have to start another one.
Hi regal,
In my personal experience, I have found that bit perfectness (in 44.1 and 48 frequencies) is not an issue with 24 bit capable transports. So far, all the 24 bit capable transports I have tried were able to pass HDCD data unharmed to the DAC.
The DSP-3 can do upsampling internally, so in that case it will definitely not be bit perfect.
I don't know about the dsp-3, but the dsp-1 works in 32 bits internally if my memory is correct.
In that case, any processing/rounding errors shoud fall under the less than 20 bit real world resolution of most DACs. Would that be audible? Hard to say without listening.
My main issue with the audio-gd digital interface and similar usb to spdif converters that use the Tenor chip (Teralink X2, Firestone Bravo...) is that they can't pass 88.2 without resampling to 96. (Please correct me if the audio-gd digital interface can pass 88.2)
I can understand why some people would want to resample from 44.1 to 96 (or 192). But doing 88.2 to 96 conversion (by the drivers or by software) is just a waste of processing power and a additional step where data could be harmed.
Would it be possible to repost your reviews from the "usb to spdif shoot out thread" in the beginning of the new thread, so that information isn't lost?
USG
Slim, A DSP (Digital Signal Processing) chip in a transport is a red flag! If we don't show bit-perfectness, hell that thing could be applying EQ or anything else. You cannot ever review a transport without first proving they are bitperfect (at 44.1k) this gives a level playing field.
I think you, as a budding reviewer should embrace this philosophy if you want to maintain credibility.
(It also helps those of us who need bitperfect for HDCD and DTS pass thru.)
I understand that is important to test bit perfectness especially for those who need HDCD or DTS pass thru. I don't have a HDCD capable DAC anymore but I will try to test bit perfectness on a friend's HT receiver.
You are right, the DSP is powerful enough that it could be doing a number of things. However, one could ask: if it doesn't raise the voulume (or compress the sound) and if any processing improves the sound, wouldn't it be a good thing for non HDCD data? Aren't all non-NOS DACs messing with the data anyway?
My main concern (besides the 88.2 capability) is the jitter reduction capability of the DSP. Recently, I found that, in my system, the sound improved a lot by bypassing the PLL feature of the DSP-1. My guess is that the "clean" clock provided by the battery powered Hiface I am using as a transport was compromised by the PLL of the DSP-1. This is of course only speculation to try to explain what I heard. I might be totally wrong about the explanation but I heard an improvement by bypassing the PLL feature on the DSP-1 (Jumper 1).
From that experience, I doubt that the reclocked digital stream by the DSP-3 can better a battery powered hiface. But since there are many other things at play (output stage, impedance,...), only direct listening experience will tell.
Erin, I agree with your explanation, but still I've read people say they fail bit-perfect test either due to hidden DSP and resampling
Non-NOS DACs use oversampling, so there will always be some kind of pre-processing of the digital data before it reaches the actual DAC.
The effects of upsampling are no doubt overstated. By carefully designing the sampler, ADC, digital processing path, and oversampling DAC, the upsampling and asynchronous rate transfer can, in my opinion, be avoided.
Your PLL comment is interesting. I might try switching off the PLL of the DSP-1 in my Ref 1 since I'm using the Ref 3, to see if it makes any difference.
The Danger with hidden EQ is it can give you a wow affect and sound great on some music but poor on others, you never want eq applied that you don't know of, you want that to be done under your control or as most prefer just the mastering engineer himself (when the CD is made.)
Oversampling DAC's just oversample and dither thats it, they don't change the data which is called mastering.
A transport that isn't bit perfect at 16/44.1 isn't a transport its a dumbed down DAW (Digital Audio Workstation.)
Oversampling is done within the DAC chip at the conversion stage, anything else is called upsampling...and should be avoided in many ppl's opinions(including mine): http://www.audioholics.com/education/audio-formats-technology/upsampling-vs-oversampling-for-digital-audio/upsampling-vs-oversampling-for-digital-audio-page-2
Hmmmm Doesn't everything ( caps, wire, cables, psu, etc etc ) in the signal path affect EQ??? Isn't that why some products can be varied to sound warm, thin, detailed, etc etc. Shouldn't it be about the Music??? Subjective?? Already ppl are making judgements about how it will sound based on pure speculation on what they think it will sound like. What about just letting our ears be the judge. If product A is technically superior and passes a bit perfect signal but doesn't sound as good as B to your ears, which one will you listen to?? I think some will actually listen to A because its technically superior, even if its sonic capability is inferior. Count me on the side of the best sounding unit, whichever technology is used.
In the case of R2R DACs such the PCM1704, there is no built-in digital filter. The digital filter has to be external and we still use the term oversampling: you can have a look at the DF1704 digital filter datasheet (see here: http://focus.ti.com/lit/ds/symlink/df1704.pdf). If you think that TI should use the word upsampling instead of oversampling, you might want to send an email...I wonder what they would respond
Richard Kulavik of AKM Semiconductors explained it this way : "This DAC is a large departure from other delta-sigma DACs designed by us and others like BurrBrown, Analog Devices and Cirrus Logic. The AK4396 is an entirely new modulator, pioneered and patented by AKM. It achieves something unique. In the past, many of the old Phillips and BurrBrown parts were R-2R* based products. These older products were looked upon as some of the best. One of the reasons was high frequency noise. In older R-2R parts, HF noise was not present. In all delta-sigma parts prior to the AK4396, everyone has fought HF noise caused from the delta-sigma modulator with the insertion of large filters and other parts to attempt to solve a problem created by the delta-sigma design. The AK4396 today effectively does not suffer any modulator-induced HF noise and is over 60dB better than the nearest Cirrus and BB devices. All of this HF noise can cause many audible artifacts downstream. That is the 'miracle' we believe is making the difference today. This part gives you the performance and linearity of a delta-sigma device with the noise performance of an R-2R part, something that was never previously available."
