All Audeze headphones are ultra low distortion, why are you throwing a marketing term at me? I was comparing the Sine's to the HE-400i which are similar size drivers, not the Mobius. Simply stating that the logic that closed-back always have better bass is not true. I never was in any way comparing the Sine and Mobius. I was simply saying that the expectation that these are going to be on the same performance level of LCD's that cost between $800 - $4,000 is a little out there and would not make any business sense for Audeze. I haven't seen anyone directly compare them with LCD-2's please refer me to the page, I would then like to know what amp they were using because the LCD-2's require a lot of power to reach there full potential, I worked my way up through several before I finally put down the cash for a Mjolnir 2 with 8w at 32ohm, 5w at 50ohm to power them. No regrets there, the step up to a fully balanced system with Mjolnir 2 and Gungnir Multibit for the DAC was quite awesome and really lets the LCD-2 shine. Do I think the Mobius's sound quality will outperform this $3,500 setup, no way.
I said not to expect LCD level bass, not Sine. I also said that I think the my iSINE20's with 30mm drivers are on par or slightly exceed my LCD-2's 106mm double-sided magnet driver bass, probably not the LCD-2C's though. What do you say to that?
Also, if you haven't noticed based on what I own, I'm a huge Audeze fan (with exception to there headbands), they have got somewhere around $3,500 out of me in the past year and a half. If i came off as being hostile towards them that was not my intention.
