Bonjour,
Im new to this forum. I would like to share my EQ for my LCD-3. I would like if you can post your EQ so I could test it.
Thank you !
LCD-3 2014 Fazor SN:271663
I also attached the Frequency Response Graph provided by Audeze.
EQ Tested
v1 : Great Soundstage, Nice high, Body 9/10
Filter 1: ON LS Fc 120 Hz Gain 6.0 dB Q 0.70
Filter 2: ON HS Fc 12000 Hz Gain 2.0 dB Q 0.70
Filter 3: ON PK Fc 4000 Hz Gain 5.0 dB Q 0.80
Filter 4: ON PK Fc 8000 Hz Gain 6.0 dB Q 0.80
v2 Full Body, Great Base, Less sparkles but maintaint nice high
Filter 1: ON LS Fc 120 Hz Gain 3.0 dB Q 0.70
Filter 3: ON PK Fc 4000 Hz Gain 3.0 dB Q 0.80
Filter 4: ON PK Fc 8000 Hz Gain 3.0 dB Q 0.80
v3 Full Body EDM ++, Great Base, High balanced to neutral
Filter 1: ON LS Fc 120 Hz Gain 3.0 dB Q 0.70 /// More Body and filing base to get a balanced soundstage
Filter 2: ON HS Fc 12000 Hz Gain 2.0 dB Q 0.70 /// Bigger Soundstage
Filter 3: ON PK Fc 900 Hz Gain 6.0 dB Q 0.80 /// Added this to boost male voices body
Filter 4: ON PK Fc 4000 Hz Gain 3.0 dB Q 0.80 /// 1/2 Female Voice Control and soundstair air and size
Filter 5: ON PK Fc 8000 Hz Gain 3.0 dB Q 0.80 /// 2/2 Female Voice Control and soundstair air and size
v4 Close to original signature, Good and detailed base and etra clarity in guitar and vocals
Filter 1: ON PK Fc 75 Hz Gain 6.0 dB Q 1.00 /// Added this to boost base (not bloated)
Filter 2: ON PK Fc 8000 Hz Gain 3.5 dB Q 1.41 /// Extra Clarity, won't change the soundstage and non-percing syllables
