Articnoise
What glue is used for the earpads? Just thrown my lcd-3 up for sale and the right one came off![]()
Use double-coated adhesive tape. (dubbelhäftande tejp)
I would like to buy new Lcd -3 ,but because i dont trust the seller can someone tell me are the LCd-3 headphones factory sealed with sticker or something like that??!?
Originally Posted by mlxx /img/forum/go_quote.gif
You can try stretching the headband so that the pads don't squeeze on the side of the head as much. Sometimes the headband can be very very tight as mine was and it took several weeks of loosening it. Even so, not sure you will be able to completely break the seal and if the pads move further away it could reduce the bass. Maybe you can place something under the edge of the pad like a pen lid to create a small air gap.
I believe the LCD4 is now using a new attachment method for the pads that releases some of the vacuum from inside but I am not sure what that does to the bass, I believe they added that to relieve pressure on the driver to reduce failures. Not sure if it can be retrofitted to the LCD3 pads though.
I've thought about cutting a piece of "marinade syringe" tube (thin metal tube) and sticking it under the back side of the pads. Feels pretty weird doing DIY mods on a 2k $ pair of headphones, but at least this would be totally reversible and I don't have to reduce the clamping force (really like how they sit on my head).
Another enthusiastic thumbs up on the new Carbon Fiber Headband!!!
Did you email them?
As I can't see the headband on there site under the "accessories/lcd-headbands" section.
