Mine has the exact same problem and it has been nagging at me but not enough to make me do anything about it. I have thought about taking it apart and trying to just bend a tab to make it even. Looking at it, I wouldn't be surprised it those tabs were bent by hand in the first place by the assembler (which would explain why so many odd pairs.)
Audeze LCD-3 Impressions Thread
- Thread starter MacedonianHero
Somphon
- Jul 31, 2014
I'm also very tempted to bend them myself. I'm guessing from looking at photos from their website, the left side is the correct angle.
DC5Zilla
- Mar 14, 2009
I've already shipped mine to Audeze directly via their support.
Guys, it's $2,000 headphone.... It has to be near-perfect. Us consumers should state the problem and give the the manufacturer a chance to acknowledge and fix it. It might lead to more strict QC or perhaps a new design for yolk that can be much more durable. I'm in no-way to bash Audeze in any way, they've been really helpful to me so far. People should definitely consider contacting them if you are facing similar issue.
- Jan 1, 2014
+1 to DC5Zilla.
If you paid $50 for a set of cans and they had to be tweaked a little bit to be aligned then no big deal. However, plunk down $2K for a "reference" headphone and you shouldn't have to worry about it coming to you in any state other than perfect. If it's otherwise then back it should go. If you bought a Lambo/Porsche/Ferrari and it pulled to the left when the dealer delivered it, I'm sure all of us would send it back until the alignment was completely dialed-in.
Having run manufacturing lines in my earlier days this type of defect is very easy to screen for - just put them on a stand (as you all have done) and see if they sit evenly. But even before they're assembled the metal tab should be checked after it is bent - just put it in a jig and measure the angles - easy to do. And finally given that the LCD-3's ship in a hard travel case they're not going to get tweaked in transit.
Hold the line on QC. Just because they're hand-made doesn't mean they shouldn't come to you in the "near-perfect" state. And finally Audeze has always been good to their word (if not better) in my dealings with them, so don't hesitate to ask them for what you need to be totally happy with their awesome products.
Happy listening and have a great Labor Day weekend
Somphon
- Jul 31, 2014
+1 to DC5Zilla.
I felt that way when I took the USD2000+ (we pay a bit more here) headphone out of the box. First thing I notice is this expensive piece of equipment leather stitching is the same quality seen from 6th grade home economic class.
Now I notice it crooked....
Jones Bob
- Mar 22, 2013
In zooming in on the third photo, it appears that the screw with star locknut that attaches the black earpod bracket to the chrome adjuster rod is not seated. Check that it is fully screwed in, as slop here will cause the assembly to appear unbalanced. Had the same problem on my LCDs.
cute
- Mar 26, 2010
I'm just new to the LCD 3.....is there a cable thread for this headphone?
Somphon
- Jul 31, 2014
Yes I see that also. Screwing it in tightly helps a bit but still the angle is wrong (which you can still see in the picture by looking at the angle of the metal piece itself in comparison to the other side)
Argo Duck
Formerly known as "AiDee"
- Nov 6, 2007
There was. Locked in 2012 so no info related to fazor models if that makes a difference. There continues to be discussion from time to time in the specific LCD threads, such as this one. Try 'search this thread'.
kkcc
- May 15, 2013
Check out the Norne Audio thread or pm Trevor TigzStudio
Highly recommended.
citraian
- Mar 15, 2012
Yes, his Draug cable is great. If you want more sparkle you can also go with the Toxic Cables Silver Widow.
Soned
- Sep 3, 2011
Thanks for the head's up.I requested mine be checked for this issue prior to shipping, not by Audeze, by the store I have purchased them from.
Laslen
- Aug 30, 2014
I just received LCD-2s with the same problem described here. I realize this is the LCD-3 thread, but I figured you'd be interested in knowing that it's not just an LCD-3 problem.
I've already contacted Audeze about it.
![](https://www.head-fi.org/attachments/1192529/)
DC5Zilla
- Mar 14, 2009
I'm little surprised there are more case regarding this issue. I don't know why not many people have brought it up till now....
Soned
- Sep 3, 2011
I was told by the dealer it has a 1 in a 1000 chance of happening.I'm happy I didn't play the odds.
