I think I'm going to have to get a Lyr..any alternatives to that? I've been using my O2 and Headstage Arrow 3G, and I think even on gain III, I'm just at the beginning of what these will sound like with a better amp..
Audeze LCD-2 Impressions Thread
- Thread starter DefectiveAudioComponent
Argo Duck
Formerly known as "AiDee"
- Nov 6, 2007
[double post]
Argo Duck
- Nov 6, 2007
^ there are many alternatives...but it depends on your budget!
And what you mean by "better amp"?
mac336
- Feb 13, 2012
does anyone know the which revision the current LCD-2 being produced is?
Maxvla
- Dec 26, 2002
2.2
mac336
- Feb 13, 2012
thanks
also looking for opinions on the stock LCD-2 cable
what kind is it and should I upgrade?
dave1109
- Aug 12, 2010
New LCD2.2 owner here, must say really like the sound.
A large leap above the HD650's I'm coming from.
- May 26, 2009
I think the stock cable is good sounding cable. An upgraded cable will be smoother and let you hear more detail in the recordings. But the stock IMO is not a bad cable.
thanks
oqvist
- Oct 28, 2004
I was quite surprised by the difference with stock compared to my sd 3 and norn but yes the bang for buck just for the sonics is perhaps not there for most people
DeadEars
- Aug 13, 2009
I agree with Frank I, the stock cable is quite good. I've upgraded to Steve Eddy's Q-audio cable, but mostly for ergonomic reasons. I went back to the stock cable for a while and I was not disappointed, even though I like the SQ a little more with the Q-audio cables. I have not heard the latest version of the Audeze stock cable, however, so YMMV.
LugBug1
- Jan 10, 2011
I use a silver poison and I can hear a difference in detail and control. The stock cable keeps them very warm sounding imo.
Andrew_WOT
- Jan 18, 2004
Unless you want to upgrade for esthetic reason, stock is fine.
thanks
Iamnothim
Name changed to sceleratus.
- Nov 15, 2012
Here's my LCD2 cable experience.
Late fall 2012, I purchased a set of used R1's The seller was kind enough to include a 2M Steve Eddy Q-cable with the stock cable despite the fact he owned LCD3's. The stock cable was longer but very bulky. It's the round one. Since the 2M Q-cable is too short from time to time I'd use the stock. To my ears I couldn't detect, I'll say, any difference.
Then a couple months ago I purchase a new set of R2's. They came with the new flat cable. Straight away I did not like the sound. The R2's were not broken in at the time, but exchanging the flat cable with the round cable or the Q-cable made a huge difference. I'll describe the new, flat, stock cable as lacking musicality. I have not given it a second chance.
Just say'n
Just say'n
mac336
- Feb 13, 2012
thanks.
Just curious does anyone know what type of wire is used in the stock cable?
thanks.
Andrew_WOT
- Jan 18, 2004
http://audeze.com/cable-single-ended
thanks.
Wire Construction
140 strands of high purity audio grade copper
20AWG for very low impedance, high current capacity with extended high frequency range
Low inductance and Capacitance
Maximum operating voltage 500V AC or DC
Very flexible, tangle free cable
Non-Microphonic
Connectors:
Professional ¼” gold plated stereo plug for input signal
Professional gold plated latching 4 pin mini XLR connectors
Electrical Specifications
Dielectric strength: 500V AC
Resistance: 170 milliohms for returned path of 2.5m long cable; this includes the contact resistance of our mini XLR connector on LCD-2 housing
Capacitance: 250 pF, including mini XLR connector on LCD-2 housing
Response: -3dB @ 12.7 MHz
Inductance: 1.8 microH
Total: 11 (members: 0, guests: 11)
