Audeze LCD-2 Impressions Thread
Jul 9, 2015 at 9:21 PM Post #6,302 of 12,838
madwolfa
Shawnee, KS
  If I understand it correctly it just uses half of the circuit.
That's not correct. Balanced signal is usually "summarized" by a special converter circuit to produce a single-ended output.
Jul 9, 2015 at 10:48 PM Post #6,303 of 12,838
WilCox
Half the balanced output is simply unused or shorted out like this:
(Line level signal example)
So you are using only half of the amplifiers capability. This is the case with the Bryston BHA-1.
Jul 10, 2015 at 10:52 AM Post #6,306 of 12,838
madwolfa
Shawnee, KS
Hmm, then I guess it's just another approach, which ultimately depends on the amp's base topology.
Jul 11, 2015 at 5:56 PM Post #6,308 of 12,838
MrD
Apologies for the length of this post - unfortunately I've always been incapable of being concise - and thanks for any advice...
I'm hoping to establish how the upper frequencies of LCD-2.2 and Fazor compare to my two current reference points, Sennheiser HD580s and Beyer T1s. As background, I'm looking for a single pair of headphones to complement my (currently hypothetical) speaker setup, which won't be able to fill a critical niche in my listening - mostly 80s/90s/00s indie rock/post-punk, with some electronic thrown in - as I find these demand to be played at volumes that aren't entirely appropriate for my listening environment.
Although I probably prefer the T1s (despite their flaws) as an all-rounder, the HD580s are more often than not decisively better-suited to that kind of material, where elevated bass is usually desirable given the general characteristics of those genres and the ubiquity of bass-thin/treble-hot recordings. And from owning LCD-2.1s in the past, I know their low-frequency extension and performance easily surpasses that of the 580s, which is why I'm looking to go back to them.
However, as a not-entirely-recovered former detail addict, I tend to find with all but the most searingly bright recordings on the 580s that I crave a little more bite with the guitars, crack with the snares etc. I'm abnormally tolerant of treble harshness, so in an ideal world I'd take quite a bit extra on top, but I appreciate it's a zero-sum game where I can't gain anything without something else (bass/mids) being taken away, so I think I'm only looking to move fractionally closer to neutral.
I know the 2.1s take things slightly in the other direction from HD580/600, but would I be right in thinking that the 2Fs have enough added treble presence to edge past the Senns while still remaining some way off the Beyers? And if not, is there anywhere else I should be looking? I'd like to consider LCD-3 but my budget and European location make that unrealistic, so if neither 2.2 nor 2F is suited I'll probably have to consider other brands.
Jul 11, 2015 at 8:07 PM Post #6,309 of 12,838
Alexalder
LCD 2F have a lot of treble, too much for me as i had to use software eq. Check the frequency response graph and compare
Jul 11, 2015 at 9:02 PM Post #6,311 of 12,838
x RELIC x
The West Coast, Canada
In a nutshell, what's the main difference in SQ between LCD-2.2 pre-fazor and the LCD fazors, closed-back only.
For one LCD-2 doesn't come in closed back. :wink_face:
The Fazor adds more coherence to the sound pressure waves leaving the driver through the magnetic structure so you'll hear more detail. I believe at the same time that Audeze introduced the Fazor wave guide they also tweaked the membrane and traces on the membrane for a faster response. Again, the result is more perceived treble and detail.
For closed back the only offering in the LCD line is the XC (which only comes with Fazor), and that has thinner and faster drivers than the LCD-2, but there is some elevated upper mids and lower treble that some may not enjoy. I love it as a compliment to my LCD-2.2 (non-Fazor).
Jul 11, 2015 at 10:27 PM Post #6,312 of 12,838
CanadianMaestro
Canada
Thanks for the insights. Yes, I'm aware that LCD-2 is only open-backed
The highs can grate on me after a while. Shall stick with my 650 and 560.
cheers
Jul 11, 2015 at 11:17 PM Post #6,314 of 12,838
x RELIC x
Anyone ever tried to put the LCD XC cups onto the LCD 2?
Might be an interesting experiment.
The prototype LCD XC looks like an LCD 2 with cups on.
There was some talk of it quite a while ago, can't remember which thread. The takeaway was it sounds terrible.
Jul 11, 2015 at 11:38 PM Post #6,315 of 12,838
Lohb
Surfing on electro
A Russian guy did it in the thread before. It measured flatter than XC objectively, but that is only half the story.
